Low Coolant Light But High Level Of Coolant, Why? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 17 (permalink) Old 02-23-2008, 11:24 PM Thread Starter
Hi, my 2002 taurus sel. this evening its low coolant light lights. however, when i checked the coolant level, it is almost full.
what the problem is? the sensor, or the coolant it too full to move?
what shall I do? thank you very much for your information.
pinseng is offline
post #2 of 17 (permalink) Old 02-23-2008, 11:57 PM
silvapain's Avatar
Bad coolant level sensor - it's a float and a magnet located in the reservoir. The magnet has a tendency to detach from the float and settle to the bottom where it triggers the low coolant level sensor. Either disconnect the sensor (located at the bottom of the reservoir), or buy a new reservoir. If you buy a new reservoir, be sure to get the Dorman revised one (clear top).
- Daniel
Current:
Past:
1997 V8 SHO Silver Frost -
1997 V8 SHO Ebony Satin -
1997 Vulcan GL -
1990 Vulcan Sable -
silvapain is offline
post #3 of 17 (permalink) Old 02-24-2008, 12:15 AM Thread Starter
Thanks for your help!
Is it possible that the coolant in the reservoir too full? because mine is almost full.
and usually how much is it to repair it?
thank you.
pinseng is offline
post #4 of 17 (permalink) Old 02-24-2008, 07:18 AM
mwt
mwt's Avatar
You have to purchase a new tank with the sensor in it.
Takes about 10 minutes to change
Mike
94gl Vulcan totalled 4-01-04
New Paint coming soon
2000 SES Duratec
mwt is offline
post #5 of 17 (permalink) Old 02-24-2008, 11:53 AM
You can't get the tank too full. Any excess will just get burped out. You should keep the tank as full as possible to keep the exposure of O2 to the coolant to a minimum.
post #6 of 17 (permalink) Old 02-24-2008, 03:42 PM Thread Starter
Thanks for everybody's help!!
It's very useful to me!!!
pinseng is offline
post #7 of 17 (permalink) Old 04-01-2008, 08:24 PM
I had the same problem with my low coolant light. I ordered the doorman part from rockauto for about $40 after shipping. It would have been an easy install if one of the two bolts was not ruined. Still only took me an hour and the light is off. It sure is nice to have the sensor working because it is important to know when something in the cooling system springs a leak...which seems to be happening to me lately.
kwegman003 is offline
post #8 of 17 (permalink) Old 05-08-2008, 03:29 PM
perfect timing. this is happening to my taurus and i just did a full system flush and cleaning. then the light stays on and i'm just thinking wtf? so now i gotta replace the tank and buy another jug of coolant...sweet
<span style="font-family:Arial Black">97 Taurus LX
August 2007 COTM
Check out my
enasnidx is offline
post #9 of 17 (permalink) Old 07-21-2008, 03:57 PM
Oldwolf's Avatar
OK...I&#39;ve been a member for about 5 minutes and this is the solution to one of the problems I have been having.
It&#39;s $39 at AutoZone (for the Dorman).
~Brad~
‹^^^›_‹(•¿•)›_‹^^^›
Oldwolf is offline
post #10 of 17 (permalink) Old 07-21-2008, 09:37 PM
I replaced mine about 2 weeks ago. I ordered the part from parts.com I should have checked here and then I would have known it was a part available at Autozone. Still, it was pretty convienient to just order it online and not have to make a trip to Autozone to order it, then go back in a week to pick it up. Mine is a genuine Ford part, but it is a clear jug like the Dorman one described. I liked the black cover from the original better. I think the Ford part ran me about $50.
If you are not going to stand behind our troops,
then you should consider standing in FRONT of them.
99 Sable LS
ken_23434 is offline
