Random P0300 Code | Intermittent - Taurus Car Club of America : Ford Taurus Forum
post #1 of 57 (permalink) Old 12-26-2007, 01:36 PM Thread Starter
michakaveli's Avatar
Send a message via AIM to michakaveli
I bought the code reader at Harbor Freight Tools and I have been getting these P0300 codes, sometimes they read as pending, without the actual CEL illuminating.
The car has been running well since I had the fuel pump replaced and the fuel rail sensor replaced. Sometimes when it starts it may stightly hesitate, but it's gotten a lot better since those repairs.
Any thoughts? Mileage is around 23-24 MPG combined city and hwy
michakaveli is offline
post #2 of 57 (permalink) Old 12-26-2007, 02:08 PM
Are you erasing the codes after checking them? If you are, and the code keeps returning, it is likely an ignition issue.
I had P0300 and P0316 on my '02 and by replacing the spark plugs and wires, the codes went away.
2003 Mercury Grand Marquis
2002 Taurus SE "Evelyn" 221K+ miles 3.0 Vulcan AX4S - RIP
1995 Taurus GL "Bonnie" 72000 miles 3.0 Vulcan AX4N - RIP
If you need help with a Taurus problem, feel free to PM me or
rdh2 is offline
post #3 of 57 (permalink) Old 12-26-2007, 02:15 PM Thread Starter
I do erase the code after it appears. I have replaced the plugs but not the wires. I assume that's a safe bet next. I'm at 79K on my Taurus Vulcan
post #4 of 57 (permalink) Old 12-26-2007, 10:52 PM
It could also be an intermittent fuel problem, like a sticking or leaking injector, or the coil pack itself.
- Barenaked Ladies
Nidan is offline
post #5 of 57 (permalink) Old 01-03-2008, 11:40 AM Thread Starter
*UPDATE*
I replaced the plugs wires with some AZ units. Performance of the engien has improved as the engine runs smoother, less vibration in the steering wheel. But the P0300 code still comes on or is pending, per my code reader. After I replaced the plug wires I topped the tank w/ 93 and took a 350-400 mile trip. I set the cruise control for about 78-79mph on the way to my destination and averaged 25.5mpg. Awesome for approx. 190 mile journey. On the way back I filled up with 87 octane, and yielded only 23.4 mpg. Both Hess stations but different locations.
This morning when I started the car (in the high 20's) it started with the revs going to 1k then usually they drop to 300-500rpm and come back up to 1,500 until it settles @ approx. 1k. It does this routine every morning but this morning it actually stalled when it dropped to it's 300rpm range and never came back up. It stumbled for a second or two. When I attempted to start it again it started with no issue. The engine runs smooth, no other abnormalities.
I check the ECM with my code reader after and I had a "pending" P0300 which I cleared....
I'm leaning towards replacing the coil pack. Otherwise the car runs fine. When I start it later in the day she comes to normally. Most people would probably leave it alon but I don't feel like getting stuck somewhere.
Any thoughts?
post #6 of 57 (permalink) Old 01-03-2008, 12:10 PM
What kind of plugs?
FWIW 93 octane will actually burn cooler than 87 octane.
post #7 of 57 (permalink) Old 01-03-2008, 01:25 PM Thread Starter
What kind of plugs?
The plugs are Autolite Double Platinums from Autozone. I read one of the threads regarding spark plugs and went with an OEM like replacement. checked the gaps on all plugs before installation
post #8 of 57 (permalink) Old 01-03-2008, 02:47 PM
Send a message via AIM to bob woods Send a message via Yahoo to bob woods
I had that code on my '97 a few years ago, changed the wires first, still got the code, then replaced the coil pack, problem solved.
bob woods is offline
post #9 of 57 (permalink) Old 01-03-2008, 03:54 PM
If you remove the coil pack and look at the underside, you may see some small cracks. If you do, it's junk. If you don't, it may still be ok. Often failed coil packs have tiny cracks in them which allows moisture in and causes the problems. You usually notice the problem more in the morning, when the car has been sittin overnight and moisture can accumulate, or when driving in wet weather. Often, it can be duplicated by spraying water on the coil with the engine running. It'll often start to miss when you do that, indicating a coil problem.
- Barenaked Ladies
Nidan is offline
post #10 of 57 (permalink) Old 02-25-2008, 11:38 AM Thread Starter
*UPDATE*
since the last post I have purchased a replacement coil pack from AZ w/ no difference in performance.
The OEM coil pack looks remarkable, not visible cracking inthe underside, actually looks just as good as the repalcement unit I installed.
I occasionally receive the P0300 codes as an actual DTC or Pending Fault...
I am thinking that it could be the CPS? The engine does not have a consistent behavior pattern, but nothing to drastic enought to cause driveability issues or engine stalling to date...
Thoughts on potentially bad CPS anyone? Any guidance requested...
