Member Number: 11645
Drives: 2002 Taurus SEL S/W (Vulcan)
What type of Antifreeze should I use in a 2002 Vulcan (that I just purchased)? The Owner's manual references two different antrifreezes: a green and a premium gold. It's kind of hard to ascertain the color - it's been in there a while. I've always used Prestone green for my older (1992) Taurus.
Tom Evans 1992 Gen 2 Vulcan (sold at 232,000) 2002 Gen 4 Vulcan 161,000 2002 Chev Suburban 135,000 1981 Mercedes 300SD 279,000 1982 Mercedes 300SD 292,000 |
Member Number: 1808
Drives: 2007 Mazdaspeed 3
Rep Power: 18 ![]() |
Either is fine. I use the yellow, but I remember reading online somewhere that the green is better at cooling and protecting, but needs to be replace more frequently.
- Daniel Current: 2002 Pontiac GTP 40th Anniversary Edition 2007 Mazdaspeed3 Past: 1997 V8 SHO Silver Frost - ELISJOY 1997 V8 SHO Ebony Satin - RIPElaineRIP 1997 Vulcan GL - RIPSuzanneRIP 1990 Vulcan Sable - NONAME |
Member Number: 11956
Drives: 1995 Gen 2 yo!
The Ford delear told me it's green for my 95 GL. So I bought Motorcraft green coolant from them.
![]() Clubs: TCCA-WEST COAST and SHO-CAL |
Member Number: 125
Here is the official usage chart from Ferd.
Paul Nimz '10 Red Genesis Coupe '08 Hyundai Accent |
Member Number: 5162
Drives: 2001 SES Vulcan
I know 2001s came with either yellow or green...2002s are probably the same. There was a chart posted back a while somewhere around here with a chart of which years could get what antifreeze.
Mine came with yellow...I just put back in what came with it. I'm thinking about going to either the Prestone universal stuff or basic green when I replace the water pump in a couple weeks...I'll have to do some research and decide what I want to put in it. edit: As I was posting, there's the chart Thanks Paul!
Jim S. - Pittsburgh, PA ![]() 2001 Ford Taurus SES - Vulcan/AX4S, 160k and counting 1993 Ford Taurus GL - Essex/AXOD [GONE - 147k] 2002 Ford Escort ZX2 - Zetec/F-4EAT [GONE - 73k] 2010 Ford Fusion Sport - Cyclone/TF-80 2001 Toyota Camry LE V6 - 1MZFE/A541E and EXTRA BEIGE 1988 Pontiac Fiero GT - 2.8 V6/Getrag 282 5-speed |
Thanks, SHOZ123, for the chart.
My car was manufacturered on 12/14/01, so it should have had the green antifreeze from the factory.
#7 (permalink) | |
Member Number: 4933
Drives: 2002 SEL duratec
Rep Power: 9 ![]() |
Do not use Prestone universal in any Taurus. This is an Organic Acid Technology (OAT) coolant. The Prestone "Long-Life (5yr 150,000mi)" coolant contains sodium 2-ethyl hexanoate according to the bottle, which is probably the salt formed from mixing 2-ethyl-hexanoic acid with sodium hydroxide base. From the August 2004 issue of Motor magazine: "All DexCool-approved coolants to date use two organic acid rust/corrosion inhibitors, one called sebacate, the other called 2-EHA (which stands for 2-ethyl hexanoic acid). ....The rust inhibitor 2-EHA poses another issue: It's a plasticizer (softens plastic), so it has been blamed for coolant passage gasket leakage. Softening (and the resulting distortion) was reported by Ford, which encountered gasket leakage problems when it tested a DexCool type formula on its V8 engines. Ford also saw similar issues with other gasket materials. That killed the OAT coolant idea for Ford". Use the Zerex G-05 long-life (Ford specification WSS-M97B51-A1, A.K.A. "yellow stuff") instead which is a hybrid organic acid technology product not based on 2-ethyl-hexanoic acid. A complaint has been filed against Prestone for misleading advertising in the use of the word "universal". One can also use the good old fashioned short-life green stuff and replace it more often.
2002 duratec SEL sedan - 190,000 miles 2000 duratec SEL sedan - Died of rust at 115,000 miles in 2009 1993 Vulcan LX sedan - sold after 11 years of driving and 189,000 miles in 2004 |
#9 (permalink) | |
That's what I had! The the crap I was using was yellow. Nobody told me that I was suppose to use a color specfic coolant So, I flushed it out at the dealer for the green stuff. And I have a bottle of the green stuff in my trunk in case i need it.
#10 (permalink) |
Member Number: 8024
Drives: 2006 SE Flex Fuel 60k
Before Hybrid OAT came out, I used OAT (Dex-Cool) on all my vehicles (Ford, Chevy, and Chrysler). Since I found Hybrid OAT at AutoZone (Zerex G-05 formulation, yellow stuff), I have been using it on all. I consider HOAT is an improvement of OAT..
06 Taurus SE, 97 F150, 08 Impala |
