| View Poll Results: Pick Your Plug | |||
| Autolite Double Platinum |
40 | 47.62% |
| Autolite XP Iridium |
13 | 15.48% |
| Bosch Platinum +4 |
8 | 9.52% |
| Bosch Platinum IR Fusion |
5 | 5.95% |
| Champion Double Platinum |
1 | 1.19% |
| Champion Iridium |
1 | 1.19% |
| Denso Double Platinum |
1 | 1.19% |
| Denso Iridium |
2 | 2.38% |
| NGK IX Iridum |
5 | 5.95% |
| NGK Iridium |
8 | 9.52% |
| Voters: 84. You may not vote on this poll | |||
#61 (permalink) |
The finewire Motorcraft plugs (AGSF32FMF6) are acceptable. Your car came with platinum plugs from the factory, not copper/nickel.
#62 (permalink) |
Member Number: 37321
Drives: I own a 1996 Black Taurus SHO
Rep Power: 2 ![]() |
I am a motor craft fan when it is to spark plugs.
Edit: OLD THREAD |
#63 (permalink) |
Member Number: 40570
Drives: 2006 Ford Taurus SE
Not to doubt you, but the one I pulled looked awfully widely gapped and the tip didn't look fine, it looked like a copper plug?
I will be posting pics when i change them..
2006 Ford Taurus SE / Vulcan With 35k |
#64 (permalink) |
Member Number: 35029
Rep Power: 5 ![]() |
He is right, your ignition system requires dual platinum as minimum, so that's what Ford put in.
I use in mine now NGK fine tip iridium with platinum disc welded on ground strap (NGK Laser Iridium). |
#65 (permalink) | |
Member Number: 50953
Drives: suzuki 2011
#66 (permalink) |
1. Motorcraft plugs are just average, overpriced plugs. They buy the plugs from real manufacturers (Autolite, NGK) pre-labeled with Motorcraft logo.
2. Finetip Motorcraft are platinum finetip (not iridium, that is the best) and they don't have the platinum ground strap needed by ignition by spark packs - they are made for coil-on-plug ignition. 3. For coil pack-style, Dual platinums where needed because 1/2 of plugs fire "backwards", when coil packs are used. The only finetip that satisfies that is the NGK Laser Iridium. I am not sure what style of ignition a 2006 Vulcan has. You can use the NGK e-catalog for selection, it will say if Laser Iridium or regular Iridium IX are needed. Last edited by SoNic67; 02-27-2013 at 06:01 AM. |
#67 (permalink) |
Rep Power: 21 ![]() |
^ '06 Vulcan has coil pack. As do all Vulcans.
#68 (permalink) |
Moderpony
Member Number: 7950
Drives: 2004 Taurus SES, pulled around by a vulcan
Bosch platinums. Been about 50k, still runs like a top.
#69 (permalink) |
#70 (permalink) |
Member Number: 21738
Drives: 96 Taurus Ghia DN
The Ghia with all the gear!
