99 Taurus Ax4n 1-2 Shift Problem - Taurus Car Club of America : Ford Taurus Forum
Old 07-19-2007, 08:54 PM   #1 (permalink)
Member Number: 12919
mcyork has a little shameless behaviour in the past
Smile
I have a 99 taurus vulcan ax4n transmission 1-2 shift problem. Having problems shifting 1-2. Either hesitates or goes into neutral and then 2. Some metal in trans when changing fluid. Changed transmission. Same problem. Speedo seems to be working fine. At this point I'm thinking of changing the VSS even though the speedo seems to be working? TRS seems to work when I checked online data with code reader. Any help would be appreciated.
mcyork is offline   Reply With Quote
Old 07-20-2007, 01:21 AM   #2 (permalink)
Member Number: 5485
gohim has a little shameless behaviour in the past
Are you sure you have an AX4N?
The problem you are having is a classic failed AX4S transmission symptom.
How many miles are on the engine?
A bad CPS (camshaft position sensor) can cause shifting problems. The CPS on a Vulcan engine usually lasts 70K-100K miles.
gohim is offline   Reply With Quote
Old 07-20-2007, 05:48 AM   #3 (permalink)
Arrow
Yes I have the AX4N transmission. Verified with vin # and the trans is stamped also. Like a said, I changed the transmission (Jasper rebuild) and the problem is exactly the same.
Old 07-20-2007, 08:11 AM   #4 (permalink)
silvapain's Avatar
Member Number: 1808
Drives: 2007 Mazdaspeed 3
silvapain is on a distinguished road
A floating 1-2 shift is an indicator that the pump is failing in the valve body.
- Daniel
Current:
2007 Mazdaspeed3
Past:
1997 V8 SHO Silver Frost - ELISJOY
1997 V8 SHO Ebony Satin - RIPElaineRIP
1997 Vulcan GL - RIPSuzanneRIP
1990 Vulcan Sable - NONAME
silvapain is offline   Reply With Quote
Old 07-20-2007, 11:04 AM   #5 (permalink)
Member Number: 10882
SamH has a little shameless behaviour in the past
Does it do it all the time or just under "hard" acceleration?
When I really get on it (1999 Taurus LX with Vulcan and AX4N) from a standing start then let off a little to get it to shift into second (or third) mine will "search" for the correct shift sometimes lurching and seeming to go into neutral for a few moments. It's done this since day one (bought it with only 11K on it), it now has 103K on it and it still acts the same way. My solution was not bother attempting to accelerate that hard from a standing stop. I have noticed that if you don’t let off it shifts smoothly into second (under very high RPMs) then when you lift it performs as you would expect (or hope).
SamH is offline   Reply With Quote
Old 07-20-2007, 12:44 PM   #6 (permalink)
I have discounted the transmission being the problem again. Like I said I just changed it ($1600 Jasper rebuild unit plus my time) and the same problem.
<div class='quotemain'>
It happens whether I accelerate slow or fast. The engine revs to 3-4000 rpms and then jumps to 2nd gear. I put in a new (Jasper rebuild) transmission and the problem is the same.
Old 07-20-2007, 01:07 PM   #7 (permalink)
silvapain's Avatar
Member Number: 1808
I'm glad you think it's funny. However, the transmission itself is your problem.
I have this exact same problem with my SHO, and the tranny in it was recently rebuilt and only has 4000 miles on it. I researched about it as well:
http://www.shoforum.com/showthread.php?t=76827
BTW, asking for help then insulting those with more knowledge than you and talking out your ass won't get you many friends on here.
- Daniel
Current:
2007 Mazdaspeed3
Past:
Old 07-20-2007, 07:37 PM   #8 (permalink)
Didn't mean to insult anyone. I'm looking for ideas before I do any major surgery in case I missed something. I have asked two well respected local rebuilders as well as this forum and have recieved several different possible solutions(see above). I'm changing the VSS tomorrow because it is a cheap part and easy to replace. Several forum's have suggested trying this and the local rebuilders I know. I know some of the guys at Jasper and like their products, that's why I bought one. Sorry, but I hope your wrong. Time will tell.
Old 07-20-2007, 08:35 PM   #9 (permalink)
Member Number: 5485
You didn't answer the question about miles on your engine. As I wrote before, a defective CPS (or incorrectly driven one, due to a worn-out Syncro Shaft) will cause shifting and other engine performance problems.
It is entirely possible that the problem is not your tranny. It's unfortunate that you didn't seek advice, before blowing the money on a tranny rebuild/replacement.
You can usually see a defective VSS by looking at the speedo for proper operation. But it is a cheap experiment.
Old 07-20-2007, 09:12 PM   #10 (permalink)
The Taurus has 78,000 miles on it. Would the CPS failure show an error code? I'm surprised there is not a code when the trans acts like it does. I've scanned it and had a friend scan it also. No error codes. I took advice when I changed the transmission. Wrong advice, maybe?
