Ignition Coil Bad? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 07-15-2007, 06:07 PM Thread Starter
Hi again. I recently did a "tune up' consisting of spark plugs, wire cap and rotor change. I did it because the engine started "surging" while driving, hunting between 2000 and ~2500 rpm while cruising @ 100 kph. (It does this in any gear though, so I ruled out the torque converter. Anyway, when I replaced the wires and cap I noticed the ignition coil was stongly corroded on the tip, and so was a tip on the cap (and rusty), I think it was cylinder 5, not too sure. My question is: Is the ignition coil bad and could it be the culprit of the surging? How much does one of those cost? It looks easy enough to replace. Would you recommend one from a wreckers or new only?
Thanks in advance!!
johnny28 is offline
post #2 of 13 (permalink) Old 07-16-2007, 12:17 PM
maxx_powers's Avatar
Surging is usually associated with air intake concerns, whether it be a bad MAF, IAC, or air leaks.
Matthew Wilson
SHO Crazy
(sort of)
maxx_powers is offline
post #3 of 13 (permalink) Old 07-16-2007, 01:27 PM Thread Starter
I cleaned the IAC with carb cleaner, can the MAF be cleaned?
johnny28 is offline
post #4 of 13 (permalink) Old 07-16-2007, 03:37 PM
Yes and no.
There's a company (I think Gunk) that makes a specific MAF cleaner. Use that in combination with a soft toothbrush and gently clean the wires. Make sure it's dry before you plug it back in.
I also say no because some (I'm not sure about yours) MAF's use a heated wire in their air measurement... and the application of any cleaning solution can damage them.
Matthew Wilson
SHO Crazy
(sort of)
post #5 of 13 (permalink) Old 07-16-2007, 11:56 PM
qwertz9586's Avatar
CRC makes a MAF cleaner. You just spray it on and let it dry for a couple seconds. You shouldn't touch the MAF wire at all.
The rusty wires sounds like someone didn't put dielectric grease on it on the last tune-up.
qwertz9586 is offline
post #6 of 13 (permalink) Old 07-17-2007, 02:28 AM Thread Starter
I'll check out the MAF tomorrow, but why was the Ignition coil corroded?
ps: this is a 92, and I suspect it never saw a Ford dealer since 96...from the records I have
johnny28 is offline
post #7 of 13 (permalink) Old 07-17-2007, 06:18 PM
qwertz9586's Avatar
Probably because they didn't put dielectric grease on the end connected to the coil either?
post #8 of 13 (permalink) Old 07-18-2007, 12:56 AM Thread Starter
Okay then, I did what I could to clean the MAF. Stupid security screws were in the way of actually taking out the maf proper, so I sprayed through the screen. It has improved the drivability, so I took an old torx screwdriver to work and drilled it out in a lathe, so I can get the job done proper. I'll report back when I'm done, meanwhile thanks for all the help!!!!!!!
ps: engine code "U", is that vulcan or Duratec?
johnny28 is offline
post #9 of 13 (permalink) Old 07-18-2007, 10:36 AM
silvapain's Avatar
The Duratec wasn't available until 96. It replaced the 3.8L Essex engine.
VIN code U is Vulcan.
You can buy "safety-torx" bits (torx bits with hole in center) at any local parts store very cheaply.
You don't need to remove the MAF from the housing to clean. Just spray the wires through the port.
- Daniel
Current:
Past:
1997 V8 SHO Silver Frost -
1997 V8 SHO Ebony Satin -
1997 Vulcan GL -
1990 Vulcan Sable -
silvapain is offline
post #10 of 13 (permalink) Old 07-19-2007, 11:06 PM
RickMN's Avatar
How to clean your MAF with photos
http://free-auto-repair-advice.blogspot.co...maf-sensor.html
RickMN is offline
