How Do I Adjust My Headlights - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 07-14-2007, 03:13 PM Thread Starter
Send a message via AIM to sw1tch_nut Send a message via Yahoo to sw1tch_nut
Thumbs up
ok i know what bolts/screws/things to turn.. there is one on the top and one on the bottom.. but what do i use to turn them... basically.. do this.. take a small allen wrench.. hold the straight side out.. BAM that's what i have to turn to adjust them... what tool would i use to turn those. my driver's side headlight sits VERY close to the front of the car.. and the passenger could use a little adjusting towards the center. my Xenons would look alot better if they were actually up.
interior lighting
pioneer head
memphis 5.25 front
memphis 5x7 rear
memphis 12" subs
1k watt amp
auxilary battery with 4gauge wiring
BIG BOOM LITTLE CAR
sw1tch_nut is offline
post #2 of 9 (permalink) Old 07-14-2007, 03:34 PM
fdogg96's Avatar
I though you only needed a screwdriver. I could be wrong.
If u want to do it the proper way, move ur car 25 feet from a wall, measure the heigh of the bulb to the ground, draw a line on the wall representing the same height, then adjust accordingly.
I have Xenon/HID on my 95. It''s not a good idea to raise ur lamps if they are dont need to be or if u have prismatic headlamps. It's even worster if they are foggy because it's blinding on-coming traffic. I plan to get the LX/SE discoballs and lower them.
1993 V6 3.2L SHO
Clubs: SHOCAL & SHOForum
fdogg96 is offline
post #3 of 9 (permalink) Old 07-14-2007, 04:47 PM Thread Starter
<div class='quotemain'>
well i couldn't find a spot to use a screwdriver in.. i mean.. i could take it out of the bracket and use some vice grips but there would be no way to make it accurate.. oh and one o fmy lights is a bit fogged with moisture.. anyway to lose that? one freind told me to dril a small hole in the bottom and just let it work it's way out. then plug the hole with some epoxy
interior lighting
pioneer head
memphis 5.25 front
memphis 5x7 rear
memphis 12" subs
1k watt amp
BIG BOOM LITTLE CAR
post #4 of 9 (permalink) Old 07-14-2007, 11:15 PM
fdogg96's Avatar
I will look into what tools are needed. I've never adjusted it myself, took it to the dealer. I dont know if drilling a hole would help, but regardless, if u are using pritmatic headlamps, they are not designed for HIDs. It consists of a thick piece of glass that is distorting the light and still make the lightining appear foggy. I would still suggest getting the discoballs.
Why drill the hole if u can just remove the bulb and see if the moisture goes down? If it does, u can try drilling a hole and see if that controls the moisture.
1993 V6 3.2L SHO
fdogg96 is offline
post #5 of 9 (permalink) Old 07-15-2007, 09:34 PM
qwertz9586's Avatar
qwertz9586 is offline
post #6 of 9 (permalink) Old 07-16-2007, 09:49 AM Thread Starter
HAHAHALMAO... i love that.. that's freaking awesome. lol and on another note.. thanks. 4mm.. i didn't know it went down that far.
interior lighting
pioneer head
memphis 5.25 front
memphis 5x7 rear
memphis 12" subs
1k watt amp
BIG BOOM LITTLE CAR
post #7 of 9 (permalink) Old 07-16-2007, 02:51 PM
fdogg96's Avatar
U can actually understand that diagram?
1993 V6 3.2L SHO
fdogg96 is offline
post #8 of 9 (permalink) Old 07-16-2007, 10:45 PM
qwertz9586's Avatar
They recommend using Ford's special headlight adjustment tool in manuals, but my cheapo socket set had a small enough socket for it. You're also going to need a really skinny 1/4" ratchet to get to that adjuster on the bottom behind the headlight.
post #9 of 9 (permalink) Old 07-17-2007, 12:18 AM Thread Starter
i used to work in construction off blueprints.. although it's rough as hell. yes i can read it
interior lighting
pioneer head
memphis 5.25 front
memphis 5x7 rear
memphis 12" subs
1k watt amp
BIG BOOM LITTLE CAR
