Ignition Lock Cylinder Removal - Taurus Car Club of America : Ford Taurus Forum
post #1 of 10 (permalink) Old 12-03-2006, 07:07 PM Thread Starter
Just purchased a '97 Taurus GL wagon. What's the procedure for removing the ignition key/lock cylinder? There is NO KEY for this car. Thanks.
edselsouth1 is offline
post #2 of 10 (permalink) Old 12-03-2006, 07:11 PM
Without the key you will have to drill it out I believe.
post #3 of 10 (permalink) Old 12-03-2006, 07:15 PM
Send a message via AIM to jaybs95 Send a message via Yahoo to jaybs95
Have you tried going to Ford to see if they still have a record of what key went with that car?
95 Deep Jewel Green Taurus GL 3.0
...Join the obsession
jaybs95 is offline
post #4 of 10 (permalink) Old 12-03-2006, 07:21 PM
Don't Be Stupid
Have you tried going to Ford to see if they still have a record of what key went with that car? [/b]
I think post-'96 they kept records of all the key codes. The Ford dealer should be able to cut you a new one. A locksmith can even do it without a record, for about 50-60 bucks
00tec-satx is offline
post #5 of 10 (permalink) Old 12-03-2006, 08:02 PM
Stocker's Avatar
Ford has the key code records matched to the VIN for '97 and up. You will have to go to a Ford dealer and prove ownership. You're better off getting the code from a dealer and having a locksmith cut the keys- it'll be cheaper.
Stocker is offline
post #6 of 10 (permalink) Old 12-03-2006, 08:54 PM
Don't these cars have a chip built into the key which would require that the you pay the dealership to provide the new key. Without the chip the key cut by a locksmith will only work one time
Dave
96 Duratec- 220,000 miles and going strong. Tranny rebuilt twice, DPFE replaced twice. I must really love this car to keep it so long!!
maceslin is offline
post #7 of 10 (permalink) Old 12-03-2006, 11:52 PM
Stocker's Avatar
Huh?
He has a GL, which IIRC didn't get PATS until '98.
Stocker is offline
post #8 of 10 (permalink) Old 12-04-2006, 09:30 AM
Send a message via MSN to aleks 75
While you are at it, why not convert it to a "GO" button!?
98 Ford Taurus SE Comfort Wagon
K&N Airfilter
Intake Silencer Removed
Honed & Ported upper intake
Stereo with 2x12" Subs and 6 new Speakers
Roofrack Removed
1/4 Mile: 15.9 sec @ 88Mph
0-60Mph: in less than a minute
aleks 75 is offline
post #9 of 10 (permalink) Old 06-19-2011, 07:17 PM
Don't Be Stupid
Originally Posted by rosefaj24 View Post
I have a problem with my standard ignition lock assembly. All of a sudden my key would only turn about 10 degrees in the lock cylinder. It turns enough to release the steering wheel lock but then stops and spring back to the off position locking the steering wheel. I have tried my other key and no luck. I have removed the ignition switch and able to start the car with a screwdriver. I need to remove the ignition lock assembly, but as I understand it, I must be able to turn the key around 60 degrees to align the pin hole and insert a pin/wire into the cylinder to remove it. Since I can't turn the key more than 10 degrees, is there any other way to remove the lock assembly?Thanks in advance for any help.
You can drill out the retaining pin through the hole in the column cover.
post #10 of 10 (permalink) Old 06-20-2011, 07:41 AM
^^^^ +1
And it is NOT a fun process
