99 Taurus Gap In Dash Above Gauges - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 06-05-2006, 02:10 PM Thread Starter
There is a gap developing between the gauge area and the padded dash on my 99 Taurus. Is there any way to close this gap? I do not see any clips or connectors.
Thanks for your help
rushing1 is offline
post #2 of 9 (permalink) Old 06-05-2006, 02:24 PM
spridget's Avatar
mine has started to develop the same thing. The covering is glued, and appears that it's maybe shrunk with age and the glue is coming loose. I thought about re-applying some glue and clamping it to let it set, but it's not bad enough yet for me to worry about.
RIP TCCA
'96 ES SHO -
spridget is offline
post #3 of 9 (permalink) Old 06-05-2006, 03:00 PM
I have the same problem on my 98 SE. I think the dash shrinks in the heat over time as mine won't really close if I clamp it.
1998 Taurus SE
24V DOHC
edvan22 is offline
post #4 of 9 (permalink) Old 06-05-2006, 03:36 PM
Send a message via AIM to cowspotter
Get some 3M Trim adhesive, put some between the covering and the dash, then place some heavy objects on top of the dash to hold it down. Don't clamp it, you'll end up with ugly clamp impressions. Its really common on the g3.
cowspotter is offline
post #5 of 9 (permalink) Old 06-05-2006, 04:03 PM
3M makes a very strong industrial spray adhesive with a straw attachment. Shoot this inside, then place a sandbag over the top to give it even weight. Dash delamination in 3Gs is getting to be commonplace as cowspotter said.
2002 Chrysler 300M Special - 1968 Mustang Fastback - 1994 Subaru Legacy 5-sp.
ex-1995 MTX SHO - ex-1993 Vulcan GL
TrueBlue is offline
post #6 of 9 (permalink) Old 06-05-2006, 04:06 PM
1. TrueBlue, I love your avatar.
and
2. Mine (98 SE) is delaminating the same way. too cheap and lazy to fix it (already pulled the dash all apart to replace the bulbs behind the instrument cluster)
Because being nice is overrated.
Vanagoon is offline
post #7 of 9 (permalink) Old 06-05-2006, 04:48 PM Thread Starter
Thanks for the replies. The gap is just at the border of annoying / I need to fix it. I will look for the 3M trim adhesive if the gap continues to grow larger.
rushing1 is offline
post #8 of 9 (permalink) Old 06-05-2006, 05:00 PM
LOL! I like yours too.
In high school a buddy of mine had a 21-window VW Bus.
I remember riding with him up a hill behind a semi and him screaming at the driver, "DON'T STOP, I WON'T BE ABLE TO KEEP GOING!!!!" You should put some pictures up.
Here's the spray adhesive.
[img]http://www.bettymills.com/store/images/product/AMMM2218.JPG' alt='' width='240' height='240' class='attach' />
3M Hi-Strength 90 Spray Adhesive • Easiest way to apply adhesive to large areas Stronger than Super 77. New low VOC (Volatile Organic Compound), low mist formula bonds fast with high-temperature resistance. Heavy-duty—adheres to wood, metal, plastic and decorative laminates. Ideal for quick repairs. Dries transparent. Net wt. 17.6 oz. adhesive. 24-oz. Can
Click To Buy
TrueBlue is offline
post #9 of 9 (permalink) Old 06-06-2006, 06:37 AM
photos of the Vanagon,
http://www.flickr.com/photos/ppc/set...7594157040210/
It died one too many times and I couldn't get it going again
Vanagoon is offline
