Where Is The Burning Smell Coming From - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 01-02-2006, 08:54 AM Thread Starter
after a while of driving my 1996 taurus It smells like some engine fluids are burning
I can really smell it when I turn the heat on
wtf
helppppppppppp
I'm not a pimp, Im just something like a pimp
pimpjuice2 is offline
post #2 of 9 (permalink) Old 01-02-2006, 10:29 AM
We still need more info. Just a smell coming from the heater isn't enough. Could be a number of fluids from under the hood. Trans fluid, motor oil, coolant, power steering, etc. Can you describe the smell? If you pop your hood can you seem anywhere that is wet from a leak?
the_intimidator_02 is offline
post #3 of 9 (permalink) Old 01-02-2006, 11:14 AM Thread Starter
smells like burned oil but I dont have any leaks
I had my radiator flushed not long ago now my fluid is brown again already
and I have never had my trans fluid flushed in the 3 years I owned it
post #4 of 9 (permalink) Old 01-05-2006, 11:27 AM
Sorry it took so long to get back to you. Have you noticed any loss of coolant. I was thinking of your heater core possibly leaking if there is no visible leaks. But that shouldn't smell like oil. Are you sure there is no oil leaking around the rear of the motor, between the firewall and motor.
post #5 of 9 (permalink) Old 01-05-2006, 10:12 PM
diesel600's Avatar
Send a message via AIM to diesel600
Be sure to take a look at the passenger side transmission output shaft seal (where the cv shaft goes into the transmission). This seal leaked on both our '99 and '00. When this happens it'll drip right onto the catalytic converter there, where it'll burn off and give you that smell. Could certainly be many other causes, but this is one to check.
1999 SE Duratec (My Car)
2000 SE Duratec (Parents' Car)
1993 GL Vulcan (Retired)
diesel600 is offline
post #6 of 9 (permalink) Old 01-05-2006, 11:57 PM
A 96 Taurus WITHOUT an oil pan gasket leak! How could such a thing be?
I've had the fluid flushed at least 3 times with my 97, and it looks brownish again before long too. The problem is all the crud in the resovoir. Unless you remove it and clean it out and then re-install, it will just dirty up your new coolant. Do you have a wet pass side carpet? Run your fingers thru it to feel for slippery anti-freeze.
tyrantx is offline
post #7 of 9 (permalink) Old 01-06-2006, 06:39 AM
rocketfast321's Avatar
if it was the heater core your windshild would fog up a lot also
William's Rides
EveryDay: 2001 Olds Alero GL (5-Speed) 2.4 150hp 155lb. tq
Hauler: 1984 Buick Electra Estate Wagon 3oh7 5.0 140Hp 255Tq
When you down shrooms, even fluorescent lights are mindblowing.
rocketfast321 is offline
post #8 of 9 (permalink) Old 01-06-2006, 08:07 AM
Do you have a vulcan or duratec?
We had an oil leak in the 'tec for a while, there was some kind of bolt in the block that provided access to an oil galley that worked its way loose. All of the oil dripped onto the front Y-pipe. It was so bad that when you came to a stop it looked like the car was on fire from all the oil smoke!
Put the car up on ramps and see what you can see.
2005 Ford Focus ST, Duratec 2.3, MTX-75
1972 Ford F-100 Custom, 360 V8, T18 4-spd, 2WD
FOR SALE:
1996 Sable LS Wagon, Duratec 3.0, 213,000 miles
MaxKlinger is offline
post #9 of 9 (permalink) Old 01-06-2006, 08:36 AM
Unpossible! It's either oil or trans fluid getting onto the exhaust. (Mine is trans fluid)
kirbyks is offline
