Leaking Tranny Cooler Line @ Transmission - Taurus Car Club of America : Ford Taurus Forum
Old 12-27-2005, 07:33 AM   #1 (permalink)
Member Number: 2095
Jim F. has a little shameless behaviour in the past
Thumbs down
Taurus has developed a transmission fluid leak @ cooler line fitting right at transmission. This is the upper fitting is this a common occurrence?
Could I possibly get away with cutting the factory cooler line and splicing in a hose using a barb fitting at the transmission? If so what thread size is the cooler port on the transmission? Thanks in advance...
Jim
2003 Ford F-250 XLT, SC, PSD, 4x4
2001 Pontiac Grand Prix GT
1998 Ford Taurus SE
1991 Dodge Dynasty LE
http://community.webshots.com/user/oliverpuller
Jim F. is offline   Reply With Quote
Old 12-27-2005, 09:41 AM   #2 (permalink)
Member Number: 125
I replaced both my steel factory lines with 3/8" hose. You need a 1/4" male pipe thread by 3/8" hose barb to replace the quick disconnect fittings in the tranny. Then you can then run the hose straight out and snake them under the upper radiator hose to get to the front by the cooler.
You will increase the flow through the cooling loop quite a bit by doing this. A good mod to do just for the cooling benefit.
Old 12-27-2005, 10:38 AM   #3 (permalink)
Member Number: 2095
SHOZ123, thank you! That was the info I was looking for...
Great site, I do not post much but I do frequent and gain quite a bit of information from, I have sent other individuals to this site also...
1998 Ford Taurus SE
Old 01-05-2006, 11:18 PM   #4 (permalink)
Member Number: 1445
tyrantx has a little shameless behaviour in the past
Helpful pic Paul. Which one is the return line, top or bottom?
tyrantx is offline   Reply With Quote
Old 01-06-2006, 12:12 AM   #5 (permalink)
Member Number: 125
Top one is red and hot, bottom one has blue tape on it (that you can't see in that pic) and is cold. But it really doesn't make any difference if you are just plumbing in a cooler.
Old 10-09-2008, 06:30 PM   #6 (permalink)
Member Number: 14488
mikekief has a little shameless behaviour in the past
I bought a replacement for the factory "quick disconnect" at Napa.
The manual does not say to screw fitting into trans first or to put line on fitting first. I have tried BOTH ways. Each leaks.
Must I use the method of ditching the factory fitting?
Is there some trick to getting a new factory fitting to work?
Please Help!
Thanks
mikekief is offline   Reply With Quote
Old 10-09-2008, 07:19 PM   #7 (permalink)
silvapain's Avatar
Member Number: 1808
Drives: 2007 Mazdaspeed 3
silvapain is on a distinguished road
Screw into trans first, then connect line.
- Daniel
Current:
2007 Mazdaspeed3
Past:
1997 V8 SHO Silver Frost - ELISJOY
1997 V8 SHO Ebony Satin - RIPElaineRIP
1997 Vulcan GL - RIPSuzanneRIP
1990 Vulcan Sable - NONAME
silvapain is offline   Reply With Quote
Old 10-09-2008, 07:31 PM   #8 (permalink)
fonicsmonkey's Avatar
Member Number: 15023
Drives: 2004 Taurus SES--3.0L OHV--FFV--Black
fonicsmonkey will become famous soon enough
Please Help!
Thanks
I had to apply a little bit of 'threadlock' to keep my fittings from leaking....Mine only leaked when the fluid heated up...I was able to notice it coming right from where the fitting screwed into the transmission. Hasn't leaked since I put the threadlock on.
fonicsmonkey is offline   Reply With Quote
Old 10-09-2008, 08:57 PM   #9 (permalink)
silvapain's Avatar
Member Number: 1808
Teflon tape or pipe dope works as well - I used Teflon tape IIRC.
- Daniel
Current:
2007 Mazdaspeed3
Past:
Old 10-10-2008, 04:13 AM   #10 (permalink)
Member Number: 5485
gohim has a little shameless behaviour in the past
The replacement fitting already has thread sealant/lock applied to it when you get it from Ford. Do not overtighten the fitting or install and remove, unless you replace the sealant.
I have found that new fittings can leak from the quick disconnect (same plae it was leaking from, and the reason why you replaced the old fitting) you don't clean the hose end, then fuly insert the hose end, and lastly pull on the hose after you lock it in. There is some play in the quick disconnect and they don't seal properly, unless you pull on the hose to seat it against the sealing surface inside of the connector.
gohim is offline   Reply With Quote
