Slow Starting.. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 10-24-2005, 05:54 PM Thread Starter
My car takes too long to start. vuvuvuvuvroom, as opposed to my moms: vavroom. LOL. Is this normal for a 97 Vulcan with 100K miles?
Falcon2 is offline
post #2 of 13 (permalink) Old 10-24-2005, 06:42 PM
Some engines just take longer to start. I have an '02 Vulcan that turns over a few times before it starts. The other possibility is you have a weak battery; or, less likely, a degrading starter.
sfontain is offline
post #3 of 13 (permalink) Old 10-24-2005, 06:57 PM
Or something causing the fuel pressure to bleed down after you shut the car off.
Wanna be a little more specific about when this long crank problem happens, like cold/hot/always, etc.....
Robert L is offline
post #4 of 13 (permalink) Old 10-24-2005, 07:44 PM
A weak battery can definitely matter.
2001 Taurus SES - 150,100 miles - The new child
1999 Mazda 626 - 156,100 Miles - Slow and steady
majisto is offline
post #5 of 13 (permalink) Old 10-24-2005, 08:25 PM
Send a message via AIM to turbo Send a message via Yahoo to turbo
funny thing i have a 97 vulcan with over 100k miles and to day the same thing happend to me all i did was get a new battery (durolast gold) and now the problems fixed and it now runs better.
turbo is offline
post #6 of 13 (permalink) Old 02-14-2008, 11:27 AM
Bumping an old thread here as I have a very similar problem and I hope some of you can help me.
When it is warm outside, the car starts just fine, just shy above 1second. When it is cold outside the car takes a little bit longer to start.
I have yet to check the alternator and battery (both are original), but I'm thinking that if it was, then shouldn't the delayed start occur even when it's warm? So, that's why I think it might be something else, not too sure though.
This weekend I'll test out the Alternator and battery to see if they are working good.
madhatter256 is offline
post #7 of 13 (permalink) Old 02-14-2008, 11:33 AM
Its possible that it's just cold out causing it. My 01 sometimes has to turn over a bit before starting ... it starts on the first time but maybe takes 5 seconds or so as opposed to starting right up on a warm summer day.
millermagic is offline
post #8 of 13 (permalink) Old 02-14-2008, 11:36 AM
Cycle the key a couple of times before actually cranking the starter. This builds up fuel pressure.
post #9 of 13 (permalink) Old 02-14-2008, 01:01 PM
ford_ses's Avatar
Have the battery tested...a battery from '99 is pretty old and most likely doesn't have the cranking power it had when it was new. Advance or Autozone or the like will test it for free
FWIW, my original battery finally died last winter right when it got above freezing about three weeks after it tested fine...a couple weeks of subzero temperatures finally did it in. I'd be pretty surprised if your battery still has much life in it.
Jim S. - Pittsburgh, PA
Past:
ford_ses is offline
post #10 of 13 (permalink) Old 02-14-2008, 02:20 PM
dark_fire's Avatar
I find that turning to on and waiting a few seconds before actually cranking does the trick. Starts right up every time.
<div class='quotetop'>QUOTE
dark_fire is offline
