Windshield Washer Fluid Spray Question - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 01-20-2005, 04:41 PM Thread Starter
Hi there, I have a 92 Sable Wagon.
Whenever I need the windshield cleaned at 70 mph, the spray does not go high enough on the windshield to clean it properly. I need to drop down to 55 mph for the spray to cover the windshield properly enough to clean it.
How is the fluid delivered to the windshield on the gen3/4's ? Does it have sprayers on the wiper arms? Does anyone know if the sprayers on the wiper arm system can be installed on a 92?
Thanks
Spiff
Spaceman Spiff is offline
post #2 of 11 (permalink) Old 01-20-2005, 05:48 PM
The Gen III have the little snake eye things on the hood. They do no better then the Gen II versions at high speeds. I will take a guess that the Gen IVs also have the sprayers on the hood.
Current Ride: 2004 Chevrolet Impala SS Indianapolis Motor Speedway Edition - #1752 of 4088
-3.8L SC Engine - 240 hp, 270 tq, 87,000 miles
- PFC front pads|Silverstar Ultra Headlights & High Beams|K&N CAI|Optima Redtop Battery|17"x7.5" Sort Edition F7 Rims|Kumho Escta SPT Tires
Old Ride: 1998 Taurus SE Sport with the Duratec 122k miles - October 2006 COTM
K&N Filter|JVC KD-G300|2 10" Lightning Audio Subs|450W Lightning Audio Amp|Silverstars|PFC Pads, Duralast Rotors (Rear)|EBC Greenstuff Pads and Duralast Rotors (Front)|Hadyen Tranny Cooler|Pioneer 2-way 6"x8" Speakers|Polk Aduio 6.5" components|KYBs w/ SHO Springs|23mm Rear Swaybar|Gen III SHO Wheels w/ Ponteza G009s|SFCs|FSTB|SHO Bros High Flow Y-pipe
EDIII is offline
post #3 of 11 (permalink) Old 01-20-2005, 06:04 PM
Yep on the Gen 4. And I tried installing some of those LED light/sprayers and that wasn't going to happen. They worked great until you closed the hood. Then the tubing would get crimped under the hood and it wouldn't spray. Stupid sprayer things...
I'm bad news, baby!!!
Dr.Carrico is offline
post #4 of 11 (permalink) Old 01-20-2005, 06:46 PM
I got a set of them sitting around here waiting for me to figure out how to hose them...
EDIII is offline
post #5 of 11 (permalink) Old 01-21-2005, 01:39 PM Thread Starter
Thanks for the replies. I might just go to a wrecker and look at some other models of cars and see if I can retrofit the sprayers on the wiper arms to the Sable.
Spiff
post #6 of 11 (permalink) Old 01-21-2005, 04:53 PM
Send a message via AIM to SHO 2NV
FYI, 99 and up Grand AM's have the sprayers on the arms. Those should be easy to find in the boneyard.
SHO 2NV is offline
post #7 of 11 (permalink) Old 01-21-2005, 06:04 PM
Yes, the rubber tubing for my washer lines broke, so I cut it off and used high-strength clear irrigation hose, and duct-taped it. Works much better now. Usually it won't spray high because there is low line pressure because the lines develop leaks because the hood closing causes the rubber to be bent and the heat of the engine bay wear down the rubber.
2001 Taurus SES - 150,100 miles - The new child
1999 Mazda 626 - 156,100 Miles - Slow and steady
majisto is offline
post #8 of 11 (permalink) Old 01-22-2005, 05:08 AM
Send a message via Yahoo to OvenMaster
I was wondering why the spray was dribbling out of the driver's side sprayer, so I looked under the hood and found the supply hose all cracked and leaking. Went awful fast, too; it was fine in November! Why the passenger side sprayer still works fine is a mystery though...
Tom
OvenMaster is offline
post #9 of 11 (permalink) Old 01-22-2005, 02:15 PM
Ryne's Avatar
Send a message via AIM to Ryne
IIRC the late 90's cavi's have the sprayer on the wiper arm too.
I must have the lemon as far as sprayers are concerned... mine sufficiently gets fluid on my roof and rear windshield... <_<
"I still believe in Mad Vulcan Powah." -AdamB
Ryne is offline
post #10 of 11 (permalink) Old 01-22-2005, 02:42 PM
Send a message via AIM to sfblacksel
Make that 96+ Grand Ams, I used to love those sprayers. They would freak out my passangers all the time.
2010 Mercedes C300, Steel Gray on Black, stock for now...
2003 Taurus SEL Centennial
Removed Intake Silencer, Hard-wired Radar Detector, Custom tint, Custom Stereo..........
sfblacksel is offline
