Front Struts??? - Taurus Car Club of America : Ford Taurus Forum
Old 01-16-2013, 07:00 PM   #1 (permalink)
Member Number: 52191
Drives: 2001 SEL 24V DOHC Wrecked ;-(
ArcticCat650H1 will become famous soon enough
Default Front Struts???
When I bought my new car (new to me) I was told it had new rear struts (i checked they are new), but the front one is starting to make the clunking noise. What struts do you guys recommend? How are the Monroe QuickStruts?
ArcticCat650H1 is offline   Reply With Quote
Old 01-16-2013, 07:23 PM   #2 (permalink)
I'll Be Watching You!
sousa632's Avatar
Member Number: 37681
sousa632 is just really nice
Are you sure it's the strut and not a sway bar endlink(more likely)?
John
'01 Sable LS Premium Wagon Duratec dubbed 'The Silver Bullet' , '98 Windstar 3.8
Vote for Wagon of the Month NOW!! CLICK HERE
sousa632 is offline   Reply With Quote
Old 01-17-2013, 12:53 AM   #3 (permalink)
It sounds kind of like strut clunk, but it very well could be. I have not had a chance to look yet. Also when turning left at slower speeds I often get a rubberish constant squeek sound for as long as im turning? Not the power steering, it almost sounds like a dry rubber on metal or even rubber on rubber, but only when turning left at slower speeds????
Old 01-17-2013, 04:02 AM   #4 (permalink)
JohnSawyer's Avatar
Member Number: 32868
Drives: 1994 Taurus GL sedan, 3.8L Essex engine, AX4S transmission, 165,000 miles
JohnSawyer has a spectacular aura about
I just did a bunch of research to decide which manufacturer's front struts to install in my 94 Taurus (the rubber in both strut mounts has completely deteriorated, causing clunks when going over bumps), but what I learned about Gen 1 and Gen 2 front struts might help you, if you're replacing the front struts in your 2001/Gen 4. The general consensus here and elsewhere is that for Gen 3 and 4 Tauruses, most low-to-medium cost strut assemblies/quick struts from most manufacturers (including Monroe, KYB, Moog, Raybestos, Gabriel, etc.) contain lousy strut mounts and/or bearings--often, either the bearings under the strut mount break down soon after installation, or start making annoying squeaking/grinding/clicking noises, and sometimes the mount's rubber tears. For some reason, these problems happen far less with the Gen 1 and Gen 2 Taurus equivalent strut mounts and bearings from the same manufacturers, so maybe it's not a matter of a different strut mount and/or bearing design between these generations, but rather something about the Gen 3 and 4 Tauruses that don't like "normal" aftermarket strut mounts/bearings. The recommended strut mounts and bearings for Gen 3 and Gen 4 are Motorcraft, since apparently only Ford is making strut mounts/bearings for the Gen 3 and 4 Tauruses which work the most reliably. Complete Motorcraft strut assemblies can be expensive, so a cheaper (but more time-consuming) approach is to build your own strut assemblies, which allows you to choose a Motorcraft strut mount, and your choice of less-expensive struts, springs, etc.
Here are a couple links to relevant threads here:
moog strut mounts
What's The Best Brand Of Strut Bearing?
Maybe someone else with more hands-on experience with this than me, can add more info.
JohnSawyer is offline   Reply With Quote
Old 01-17-2013, 10:49 AM   #5 (permalink)
Member Number: 25751
There was a recent post on the forum about suspension noise. You could have a dry ball joint making the noise. I had one and I was spraying oil in the top part of the front struts thinking it was a strut bearing issue. Nope it was a ball joint that I injected grease into to solve. Look for the thread because it also had a you tube video with the actual sound. The clunk could be a badly worn and lose ball joint.
I have put Quickstruts all aroung on my taurus. I like them but you have to watch quality. Some places are selling Econostruts that are a cheap version on the Quickstrut.
Automender12345 is online now   Reply With Quote
Old 01-25-2013, 08:18 AM   #6 (permalink)
repairman54's Avatar
Member Number: 1435
repairman54 is on a distinguished road
I put 90k miles on a set of Quickstruts, no issues and road fine when I sold the car. I'd use them again.
I did a full front end refresh at the time, ball joints, hubs, struts & sway links as it was at 120k miles at the time. Still tight 'n happy at 212k when I sold it.
All brand name parts, no cheapo AZ junk.
John
'09 Malilbu LS
'07 Mustang GT 3 pedals
'05 Sable 24v son's
'99 Yukon
'01 FLHR
Ski Doo's
Sea Doo
repairman54 is offline   Reply With Quote
Old 01-28-2013, 07:13 PM   #7 (permalink)
Member Number: 52571
Drives: 1993 Taurus SHO
taurusfan93 is an unknown quantity at this point
I like the monroe's. Quick struts always make everything easy too.
taurusfan93 is offline   Reply With Quote
Old 01-28-2013, 07:25 PM   #8 (permalink)
