Rear Brake Caliper - Taurus Car Club of America : Ford Taurus Forum
post #1 of 10 (permalink) Old 06-14-2015, 08:38 PM Thread Starter
Rear Brake Caliper
So today I figured out my rear caliper was shot after fluid came pouring out by the piston boot. I ordered a new caliper but my question is there a trick or any tips on removing the parking brake cable and hooking it on the new caliper mount?
Scott57350 is offline
post #2 of 10 (permalink) Old 06-14-2015, 10:41 PM
Year: 2010
Engine: 3.5L Cyclone V6
Yep
see this thread: Parking brake problem
and post no. 11 in which I wrote tricks and hints.
twiggy144 is offline
post #3 of 10 (permalink) Old 06-15-2015, 09:46 PM Thread Starter
Thanks luckly I didnt have to take any of that off. I just took a pair of chanel locks and locked them on the came right before the hook and pulled to the rear of vehicle and turned it down and it came right off. Hopefully its just as easy to put back..
post #4 of 10 (permalink) Old 06-15-2015, 10:04 PM
Scotty......it should be. You beat me to the fix but it is fairly simple. The trick is to leave parking brake OFF. Lift up cable and insert the cable into the hook.
Get a good meaty set of pliers to hold AFT and a meaty screwdriver or another set of pliers to hold up and DOWN to get into the hook.
DONT FORGET TO BLEED AND FLUSH the fluid afterward.
2011TAURUSSEL is offline
post #5 of 10 (permalink) Old 06-16-2015, 11:59 PM
breeves002
Sam's Avatar
Year: 2008
Engine: 3.5L Ti-VCT V6
Trader Score: 8 reviews
Its a pain. Yes on the meaty pliers and screwdriver!!
2016 Ford Mustang GT Premium
2014 Ford Focus Electric
Moved On:
2008 Mercury Sable Premier
2000 Sable LS Premium Duratec
1997 Mercury Grand Marquis GS
Sam is offline
post #6 of 10 (permalink) Old 06-18-2015, 05:18 AM
andrewcu's Avatar
I read that thread and how they were commenting about it being unlikely that the calipers in the rear would already need replacing. I actually had one seize up on me this past winter and somehow the caliper is the only part of the brake system covered under warranty so ford replaced it for me under warranty. What would cause a caliper to seize?
andrewcu is online now
post #7 of 10 (permalink) Old 06-18-2015, 09:15 AM
I'll Be Watching You!
sousa632's Avatar
Model: Mercury Sable Wagon
Are you sure it was the caliper and not the guide pins? The guide pins are MUCH more common to seized up if not properly lubed.
John
2001 Sable LS Premium Wagon Duratec, 194K miles and kicking, 2013 Hyundai Sonata GLS
sousa632 is offline
post #8 of 10 (permalink) Old 06-28-2015, 05:10 PM
sammy0390's Avatar
let me add myself to this thread, since today when i took my exit off the highway i saw smoke coming out of my rear LH wheel.
when i got home and took the tire off, realized that the caliper seems to have seized!
It sucks that this cars are having these problems, because the pads look like they have lots of life left in them.
Has anybody attempted to just rebuild the caliper? or not even worth it?
I drive so fast, life cant catch up to me!!
sammy0390 is offline
post #9 of 10 (permalink) Old 06-28-2015, 05:12 PM
sammy0390's Avatar
One more thing: is it going to be the same Caliper for the AWD too? I hope it doesn't have a different set up.
post #10 of 10 (permalink) Old 06-29-2015, 01:02 PM
This is the Ford website parts catalog. There is a section to enter VIN and narrow down choices. Catalog shows about four choices depending on your suspension. My guess is one of the choices is SHO Performance package.
Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
1998 Taurus - right rear disc brake not working wulfdog Suspension, Handling and Brakes 1 07-06-2014 12:57 PM
Rear disc brake questions Roger, Roger Suspension, Handling and Brakes 11 02-02-2014 08:36 PM
What parts do I need for a rear drum brake job? procter Suspension, Handling and Brakes 23 11-19-2013 11:18 PM
Gen 1 Wagon Rear Disc Brake Caliper Mounts alpine67 Wanted to Buy 3 11-02-2013 07:44 PM
Wagon Brake Caliper Rear Mounts alpine67 Suspension, Handling and Brakes 4 10-19-2013 04:59 PM
