Creaking front suspension? - Taurus Car Club of America : Ford Taurus Forum
Old 01-06-2013, 12:58 AM   #1 (permalink)
whistler's Avatar
Member Number: 3733
Drives: 2011 Taurus SEL
whistler has a little shameless behaviour in the past
Default Creaking front suspension?
Hey everyone.
I have a 2011 Taurus. I've just noticed that the front suspension seems to be "creaking". The weird part is I ONLY notice it on speed bumps or traffic humps. When I go over them at slow-moderate speed (the speed you'd normally take a speed bump or hump at) the whole front end seems to make what I'd describe as a creak or scraping noise as the suspension travels. It MIGHT be coming more from the driver side but it is hard to tell. I don't really notice it on any other roads.
It is pretty cold here right now (14F). I thought that maybe there was ice built up under there somewhere that was causing it but I knocked everything loose that was around the wheels and it still makes the noise.
Any idea what could be causing this? Hopefully it will warm up and I can see if that helps it. I don't remember ever noticing it before the temperature dipped down.
whistler is offline   Reply With Quote
Old 01-06-2013, 02:08 AM   #2 (permalink)
Breeves002's Avatar
Member Number: 49890
Something needs to be greased. Check the strut boots. Could be ball joints.
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
Old 01-06-2013, 07:38 AM   #3 (permalink)
Member Number: 33869
The bushings between the subframe and body Squeak with age. Have a front end shop check them. Uni body sits on subframe at bushing. That will be 2 cents please!!
Old 01-14-2013, 05:45 AM   #4 (permalink)
Member Number: 47124
Drives: 2011 3.5L SEL
mattcow has a spectacular aura about
I noticed this as well on my 2011 SEL. I have experienced this with older vehicles (7+ years) - as the bushings get old they tend to squeak and even more so in the cold. I used to just give all the bushings a shot of silicon lub which would fix it for about a year, but I am surprised that my 2 year old taurus is doing this.
Makes me wonder what other parts Ford cheaped out on.
mattcow is offline   Reply With Quote
Old 01-21-2013, 07:19 AM   #5 (permalink)
Member Number: 45965
Drives: 2011 Ford Taurus Limited
Ford13 is on a distinguished road
i was about to post about the same thing. mine does a crackin sound. only when i make turns tho... more so when i make right turns. i hear what seems to be the front left wheel or suspension cracking/creeking. .... ???
XPLIZIT CAR CLUB COUNCIL.
Ford13 is offline   Reply With Quote
Old 01-21-2013, 08:05 AM   #6 (permalink)
Member Number: 46631
Drives: 2008 Sable Black
Jeffkww is an unknown quantity at this point
My '08 Sable makes the same sound,
I might have to give the silicon spray a try
Jeffkww is offline   Reply With Quote
Old 03-01-2013, 10:15 AM   #7 (permalink)
Member Number: 49554
Drives: 2013 SEL
hishalls is an unknown quantity at this point
My new 13 SEL began making thumps and rattles after having it 2 months. Speed bumps, entrances to driveways, tight turns all caused the noises, but they were intermittent and did not happen every time. I intentionally waited until the noises were mostly reliable before taking it in. First trip to the dealer resulted in "sorry, but we couldn't hear anything but normal suspension noise". Seriously? This car is so quiet that you can hear the slightest of noises, but I've never had a car make any noise in the suspension other than the swish of oil through the shocks.
Fortunately for me, the left front strut oil seals began to leak and evidence was now on the inside of the front rim, and the noises increased to all the time. Second trip to a different dealer was met with "your left front strut needs to be replaced- I've ordered the part and we'll replace it next week".
Done. I'm not crazy, and now it makes no noise at all. My first thoughts were sway bar bushings because of occasional "thumps", but it was the strut.
hishalls is offline   Reply With Quote
