MY 2006 Ford Five Hundred SEL - Taurus Car Club of America : Ford Taurus Forum
post #1 of 24 (permalink) Old 03-13-2017, 06:38 PM Thread Starter
Hey all, it's been awhile since i posted to this forum. and ive actually had this car for awhile now so i figured why not. excuse me if its in the wrong place.
Anyway here goes. this is my 2006 Ford Five Hundred SEL. a little history when i first got to this forum i had a 1999 Ford Taurus SE which i lost in a Wreck Last year. promptly replaced by a 2005 Ford Taurus SE which died a rapid death due to a Cooling System issue. well needing a new car i took to craiglist with limited funds to Test Drive a 1998 Green Taurus that was in rough cosmetic shape but had some mechanical issues that immediately haulted any plans to buy it. next was a 2006 Ford Five hundred i found on Craigslist for 1100 Dollars. i've had the car since June 2016 & it had then abit over 185,000 miles since then i've gotten it past 200,000.
the car was in the shape it was in when i bought it. Cosmetically on the exterior the paint isnt in the best conditon and it looks like it may have been repainted. the Rear Bumper is Cracked and theres a Large Dent in the Driver Side Fender. on the interior the Leather surfaces are Well Worn. the Headliner was dirty and sagging when i got it. some trim pieces were broken.
The Engine seems fine though it did overheat once in Gridlock traffic on a 100 Degree Plus Day.
the Most prominent issue is the Aisn 6 Speed Automatic Transmission. it Shifts Normally 1-4 but when it upshifts up to 5th there's a Delay & a Jerk. its not that Noticable under light throttle when the fluid is still cold. shift behavior gets worse with hard driving.
when the Transmission gets Hotter it starts shifting Harshly in others gears in addition to 4-5.
by then it'll sometimes shift with a Snatch in nearly all gears then slip going into 6th.
by that point the CEL & Service Required Wrench light also illuminate from the Torque Converter Failing to Lock.
Throughout all this the car has Continued to Crank up & Drive Reliably to and from work.
the only downtime this car has had is when.
Ac Compressor Seized up & Chewed the Serpentine Belt - Replaced with a New Compressor but not yet charged.
Car Battery Died in the Heat of summer - Replaced with a New one.
Screwed up the wiring harness leading to a Open Circuit in the start circuit - Fixed.
Cosmetic issues Aside the issues i know the car does or may Need is as Following.
Motor Mounts*
Probably Transmission Mounts Too*
Wheel Bearings*
More Than Likely Springs & Shocks All Around*
Brakes & Brake Rotors*
Possibly Cooling Fans*
AC Compressor New - Needs to be Charged*
Last time i got an Oil change some of the Notes pointed to a POSSIBLE rear main seal Leak.
some Minor annoyances are
ignition switch causes the Dome Light to randomly come on unless the key is Jiggled.
the Driver side Window Regulator went out.
anything else i didnt mention maybe will come to me later.
The car has Held up despite the aformentioned issues. so im deciding if i should Fix it or junk it.
99Bluebull is offline
post #2 of 24 (permalink) Old 03-13-2017, 06:42 PM Thread Starter
some pictures...can take more if requested.
ID:	188713   Click image for larger version
post #3 of 24 (permalink) Old 03-13-2017, 08:08 PM
UKfordguy's Avatar
Year: 2013
Engine: 3.5L EcoBoost V6
I'd say cut your losses. IF the body and interior were in good condition maybe it would have been worth fixing. The money you would sink into it you could put towards another car.
It sounds like that prior to you the poor girl had a poor life and all the neglect over the years are now taking it's toll.
My personal opinion would be not to sink a ton of money into it as more likely than not more issues will arise.
"superbia in proelio"
2013 Taurus SHO with Performance Package
- Air Raid Cold Air Intake
- Magnaflow twin pipes with performance mufflers
- Red rear SHO badge
UKfordguy is offline
post #4 of 24 (permalink) Old 03-13-2017, 09:23 PM
Do you work on the car yourself or do you pay dearly for the stuff to get fixed.
If it really overheated, the head gaskets could be just hanging on.
Automender12345 is online now
post #5 of 24 (permalink) Old 03-13-2017, 09:59 PM
^ He might be lucky on an overheat since the 500's have the 3.0 tec eng.
post #6 of 24 (permalink) Old 03-13-2017, 10:02 PM
UKfordguy's Avatar
Year: 2013
Are the Duratec known for being strong engines?
post #7 of 24 (permalink) Old 03-13-2017, 10:17 PM
They'll tolerate/withstand an overheat much better than a Vulcan or a 3.8 Essex.
post #8 of 24 (permalink) Old 03-13-2017, 10:25 PM
UKfordguy's Avatar
Year: 2013
I'd like to get an AWD for my winter vehicle.
post #9 of 24 (permalink) Old 03-13-2017, 11:25 PM Thread Starter
To Awnser a few statements yes i do believe the car was Handled roughly prior to me obtaining it. just by the condition it was in the first time i saw it.
Call it a Crapshoot to buy this car but i was in a Tight spot at the time and nothing else in the amount of money i had to work with during fared much better.
i Find it Strange & Interesting that a Duratec 3.0 can survive overheating better than a Vulcan 3.0...but luckily the car wasnt Hot for long as it was pulled over at the next exit and allowed to cool.
Some other issues with the car is the Front End Alignment isn't Great.....holding a straight line requires the wheel to be off center & there is Noticable play in it. plus there's a Strange Feeling when driving in wet weather like the Two front tires arent following the same track...so the car likes to Wander when its wet outside. requiring extra caution when driving in the Rain. sometimes its Nerve Wracking.
The Front End makes considerable noises. like if you let off the brake pedal from a dead stop there's clunking suggesting looseness somewhere up there. the Front End Looseness amplifies the harshess of the transmission shifting as well emitting a Loud Bang. im quite sure all mounts need replacing.
Taking Certain Turns causes a strange crunching Feeling underneath the Floorboard. ive felt this feeling in my 99 Taurus before and based on the location im quite sure its the Rear Driver side Subframe mount.
Other than that the Engine is probably the Best part of the car...that probably has some miles left on it....but the transmission is on its Last Legs.
if i do end up getting another car i may end up parting out the Five Hundred.
post #10 of 24 (permalink) Old 03-13-2017, 11:49 PM
UKfordguy's Avatar
Year: 2013
It sounds like you have answered your question. Hey we have all been there my friend, and wore the T-Shirts!
Paul's 2006 Ford Taurus SE (TaurusDailyDriver) TaurusDailyDriver Taurus and Sable Project Log 639 10-18-2015 05:50 PM
2006 Ford Taurus SE bigalnc Introduction Forum 5 06-17-2014 10:07 PM
2006 Ford Taurus Stuck Accelerator Cruise Control Cable Fix JudoJNoble 5th and 6th Gen Maintenance and Repair 0 05-20-2014 08:54 PM
The Historic '03 Red Wagon dlc360 Taurus and Sable Project Log 20 06-24-2013 09:57 PM
2006 Ford 500/Taurus won't start on Hill nose pointing up!!!! chutch 5th and 6th Gen Engine and Drivetrain 18 03-30-2013 04:28 AM
