The mystery rattling - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 01-08-2017, 07:33 PM Thread Starter
Ok...i have this odd rattle sound that's coming from under the passenger side dash.
Only happens at highway speeds.
Doesn't matter if HVAC is on or not.
It's not something in the glovebox.
Thoughts?
https://youtu.be/xmIf7oGLbt4
Shantheman is offline
post #2 of 4 (permalink) Old 01-09-2017, 07:03 PM
brn
brn's Avatar
Year: 2013
Engine: 3.5L Ti-VCT V6
Drives you crazy, doesn't it?
First and foremost, verify it's coming from where you think it's coming from. I had a rattle that I swore was coming from the dash, between the seats. It wasn't until I had someone else drive and rode in the back seat, that I figured out it was really coming from behind the driver seat.
If you haven't yet, have someone [safely] crawl around the car while you're driving to really isolate the rattle. Or you crawl around while someone else drives. If you still think it's coming from passenger side dash, remove the glovebox and look around in there (while recreating the rattle).
Rattles are tough. I spoke to a Service Manager about how they locate rattles. They actually put several microphones in the car, locate where it's loudest, re-position the microphones, repeat until located. Even then, they're not always successful.
brn is offline
post #3 of 4 (permalink) Old 01-09-2017, 11:25 PM Thread Starter
Hmm...good thought. (I was kinda hoping someone on the forum would say "OH! I know what that is! I fixed that in my car!")
I actually had my wife verify it was coming from somewhere in the dash on the passenger side...and she attempted reaching up in the dash to see if she could locate the source.
My hunch is it's related to air coming thru the HVAC system and causing one of the shutters/doors to rattle. Either that...or something is in one of the ducts. A nut/bolt/screw...something.
I guess i'm gonna have to start taking things apart!
post #4 of 4 (permalink) Old 01-10-2017, 07:08 PM
brn
brn's Avatar
Year: 2013
Rarely that easy. Mine turned out to be a rock that had wedged itself between a heat shield and some insulation under the car.
If you haven't yet, pull the glove box.
Ford Taurus HVAC Cabin Air Filter Replacement Guide - 2010 To 2014 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions
It's easier than the linked instructions make it look.
When I thought that was the case in my car (it wasn't), I duck taped a smaller tube to a vacuum cleaner hose, stuck it down the vents, and started sucking away. If that is the case for you, that might be worth a shot.
brn is offline
Rattling sound that seems to move Annorax Maintenance and Repair 13 01-12-2016 06:23 PM
Rattling Noise Isolated (What is it?) Tikko21 Maintenance and Repair 14 08-11-2015 11:31 AM
2000 dohc taurus p1237 and rattling noise hight24 Maintenance and Repair 7 09-30-2014 12:05 AM
Found this mystery hose Help? WarpedBlonde Maintenance and Repair 5 08-04-2014 10:52 PM
help please. rattling and p1633 xkate311x Maintenance and Repair 2 07-02-2014 02:35 PM
