alignment -shocks-struts - Taurus Car Club of America : Ford Taurus Forum
 2Likes
  • 1 Post By loudsho92
  • 1 Post By KULTULZ
post #1 of 7 (permalink) Old 03-20-2017, 10:21 AM Thread Starter
Do bad shocks and struts prevent a car from having a tire/wheel alignment?
red owl is offline
post #2 of 7 (permalink) Old 03-20-2017, 03:36 PM
If your ride height is off, then yes, if it is good, then OK. If you have a wagon you have rear shocks, otherwise all 4 corners are struts. Shocks/struts do not effect ride height but springs do and they break, rust and get weaker. I have had 4 Bulls break springs, all of mine just the bottom part of the first coil. Driving a car with bad shocks/struts is risky. Broken springs more risky.
post #3 of 7 (permalink) Old 03-20-2017, 07:09 PM
Yes they do affect alignment.
Automender12345 is online now
post #4 of 7 (permalink) Old 03-21-2017, 11:11 PM
Cool
The only way struts affect alignment is if they are damaged. It is springs that affect alignment.
92 White SHO
loudsho92 is offline
post #5 of 7 (permalink) Old 03-22-2017, 07:57 AM
I am on Bull #7 & #8, all bought used. I replaced the struts all around on all except '95 which I put in new front springs but not struts, gave the car to my daughter. Never had an alignment done. Only adjustment is toe and I do that with a string line. For me struts have never changed alignment. Inner tie rod of course does change toe. Only done inners on 2 of my Bulls.
One of mine, think it was '01 was hit in a parking lot in the front wheel and needed a new wheel. Insurance paid for the wheel and alignment. Shop checked it and said it was fine as is.
post #6 of 7 (permalink) Old 03-22-2017, 08:59 AM
I had the broken spring protector recall performed on my 2001 years ago at Ford and they refused to do a front end alignment. Said it was not needed and not covered by the recall.
post #7 of 7 (permalink) Old 03-25-2017, 07:52 AM
KULTULZ's Avatar
* Strut Mounts- Frt
* Ball Joints- Frt
* Spring Sag/Broken Spring - Trim Height
* Inner/Outer Tie Rod Ends - Toe
* Rack Mtg Bushings - Toe
* Bent/Damaged Strut
* Worn/Bad Wheel Bearings
Only a tight suspension/steering system will hold an alignment.
andrewcu likes this.
KULTULZ is offline
Replacing 2009 Taurus Struts SnoShark 5th and 6th Gen Maintenance and Repair 16 02-11-2016 05:14 AM
Upgraded to Severe Service Struts & Shocks 2015_SEL 5th and 6th Gen Suspension, Handling and Brakes 0 11-20-2015 12:47 PM
Rebates on Monroe, KYB and Gabriel Shocks & Struts RockAuto RockAuto 0 04-27-2015 04:57 PM
Some Articles I've Written - Sways, Shocks, Alignment, etc. Rennmeister Suspension, Handling and Brakes 0 03-21-2015 11:33 PM
Is an Alignment Necessary After Replacing Struts? 2004SESSport Suspension, Handling and Brakes 4 05-08-2014 12:07 PM
