Which shocks/struts are best for my Taurus - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #11 of 15 (permalink) Old 05-20-2016, 11:56 AM
Year: 2000
Hello all,
I have done some research on the forum regarding to replacing the rear strut with Quick Strut. As far as I see, the most difficult part is to remove the bolt connect the strut to the mounting.
Question 1> How difficult the job is for a junior DIY? Is it true that bolt is very easy to break off because it has been rusted and stuck with the mounting bracket? Any tricks for me so that this job is DIYable and I don't accidently break the bolts while loose it out?
Question 2> For the Stabilizer Bar and Connecting Link, can I simply cut in the middle to remove it because I will replace them with new ones anyway?
Thank you
q0987 is offline
post #12 of 15 (permalink) Old 05-20-2016, 12:02 PM
^ Heat, lube, loosen/tighten sequence and prayer... If 1 breaks, you can drill it out and replace it with a grade#8 7/16" bolt 2-3" long with a matching nyloc (plastic insert) nut. Remember, you have to remove the rear deck to expose the top strut bolts/nuts. Cutting the endlink in the middle won't help. Would need to cut bolts/nuts. Lotsa pb-blaster.
post #13 of 15 (permalink) Old 05-20-2016, 12:13 PM
Year: 2000
@sheila,
I never used the torch before and find the following items through HD.
Bernzomatic WT2301 Self-Igniting Basic Torch Head-336737 - The Home Depot
Bernzomatic 14.1 oz. Propane Gas Cylinder-304182 - The Home Depot
Q1> Is this simple self-igniting torch good enough for this job?
Q2> If I apply heat, the fire will burn the penetrating oil away. Is that fine?
Q3> Do I need an alignment after the replacement of the rear struts?
Thank you again
q0987 is offline
post #14 of 15 (permalink) Old 05-20-2016, 12:21 PM
Use MAPP gas instead of propane.
post #15 of 15 (permalink) Old 05-20-2016, 01:12 PM
ice445's Avatar
Ive seen a mechanic just cut the sway bar links with an oxy torch to avoid having to load the suspension. Saves a little time
ice445 is offline
Ford Taurus Reliability - Better Info mkaresh Taurus and Sable General Discussion 73 11-21-2016 02:46 PM
The Tamaro or I call her Sinnamon: A True Transformation!!! Tamaro Taurus and Sable Project Log 34 11-26-2015 12:53 PM
Putting a Taurus X Front end on my 2008 Taurus Deggy67 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 4 11-23-2015 09:58 PM
Spark Plugs unit731 Engine and Drivetrain 13 07-19-2015 02:57 PM
New member, 2nd Taurus, 4th Ford, former GM'er Rob Lee Introduction Forum 11 06-06-2014 10:57 AM
