Member Number: 50013
Drives: 1998 taurus sho v8
Can anyone tell me where to buy rear camber/toe adjustment bolts,mine are too rusted to work with and I
will have to cut them off?The car is a 1998 Taurus SHO.Thanks in advance.http://www.taurusclub.com/forum/imag...ies/unsure.gif
Member Number: 4817
Drives: 1992 Taurus SHO
Rep Power: 15 ![]() |
If you need more adjustment in the rear we have adjustable rear control arms which are much better then stock: Ingalls Adjustable Rear Control Arms SHO Source
We could probably get some good used hardware that is rust free as well.
92 White SHO ![]() -Performance: Turbo 297hp 279ftlb -Drivetrain: CM Clutch,SHONut Mounts,QUAIFE -Suspension: SS Coilovers, 24/26mm,Poly,Gen3,H-Brace, Subframe -Brakes: Cobra front, 11.6 rear -Looks: Sound System,Speedhut,Pilot Fogs,Clear Corners,Gen2 Console, CF Cowl Hood & Trunk http://www.shosource.com |
Member Number: 43942
Drives: 2010 Taurus SHO, 402B pkg, modified.
Rep Power: 3 ![]() |
Specialty Products Company | SPC Alignment | The Automotive Alignment Leaders
If the above link is only half showing (as far as the products)...... Just go back to the top of the page and click on the tab that reads "application guide". Punch in your vehicle info and proceed from there. Hope it's of some help to you.
![]() Pictured above, my 2010 SHO, #690 of 1,064, too many mods too list.... 400AWHP/433AWTQ, best time so far 12.37 @ 111MPH.... JANUARY 2013 COTM WINNER |
Just need the hardware at this time,money is tight this time of year.
That link I gave you, is for hardware only, including just adjustable rear cam bolts, etc.
If you don't see what you think you may need, give them a call and let them know what you're looking for..... Their staff was EXTREMELY helpful when it came to resolving my issues on my 2010. Again, good luck
#6 (permalink) | |
Member Number: 4817
You will need to press out the bushings and push the new ones back in. This can drive up the cost i nthe end which makes the adjustable control arms more worth it.
I would like to buy the used hardware if possible.Thanks again
Member Number: 4817
Send us an email to: info at shosource dot com
Once we get the email we can get get you a quote and get things going.
