Front brakes tomorrow - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Old 11-30-2012, 05:00 PM   #11 (permalink)
Member Number: 48743
Drives: 2003 Taurus Wagon 3.0 Liter Vulcan Autolite DP plugs Purolator Airfilter Ca
Mark Oreman is an unknown quantity at this point
I just went with the gold. I reused the OEM rotors because they are fine. All is well. Have a little more bite then OEM (Not bedded in yet either so I can't wait until they fully kick in.)
Now i have ceramics on all 4 wheels. I feel... stoppable (Sorry bad pun but had to)
Oh BTW when i took out the OEM pads the backing plate feel off 3 of the 4. Also the inner pad is different from the out. Out pad had a cleave down the middle, the in pad was flat?
Mark Oreman is offline   Reply With Quote
Old 12-01-2012, 09:35 AM   #12 (permalink)
Member Number: 11699
Drives: 2003 SES DOHC *** 2004 Sable DOHC
rdanville has a little shameless behaviour in the past
Sure these were OEM??
rdanville is offline   Reply With Quote
Old 12-01-2012, 05:13 PM   #13 (permalink)
Yes, only I owned the car.
Also the bite has really kicked in. The peddle is a whole lot stiffer.
Also they have made my rotors darker? lol I'm sure it is fine but still
Old 12-01-2012, 11:08 PM   #14 (permalink)
fct
Member Number: 10774
Drives: 1999 Duratec
I have used OEM brake pads and rotors until the brake pads were perhaps 2mm thick. A this point, it seems like the rotors were short too. I suggest to swipe a finger across the rotor surface. If you feel like it's uneven, then perhaps it's time to replace rotors as well. In my experience, it's been the case that on many cars the OEM rotor will not last through two sets of brake pads anyways.
fct is offline   Reply With Quote
