#11 (permalink) |
If the struts move with the sway bars connected, then they're loose! The struts should not really move, they only compress and pivot.
If your at a 10/16" change over 16" then that would be a camber of -2.2º. |
#12 (permalink) |
I'll Be Watching You!
![]() Member Number: 37681
Endlinks have no effect on alignment. Worn springs(most likely), bad strut mount, bad ball joints, bad wheel bearing, worn LCA would be the culprits.
On a side note...... please use some sentence structure with capital letters, and proper punctuation. It's hard to read the initial post. To me it looks like one run on sentence...........
#13 (permalink) |
Member Number: 51203
Drives: 2008 Dodge Charger
2010 Chevrolet Tahoe LTZ
2007 Ford F-350
sousa,
For the 4th damn time, I KNOW IT'S NOT THE END LINKS!!!! oh sorry bro i didn't know this was a composition course also, or that they were English nerds on TCCA, what a joke, and if you would of actually read my initial post you would of read that i replaced all parts new. |
#14 (permalink) |
2007 Ford F-350
Ok to those who are serious.... ruled out whole sway bar dilemma and still didn't change.. now i have officially replaced everything on both sides, except for the cv axle. I dont think the cv axle should change anything though. Right? Another alignment shop said that they can repair the problem the same way like any other alignment... is that true??
#15 (permalink) |
![]() Member Number: 49890
Moy, please watch what you're saying. Sometimes people don't understand that you DON"T always have to reply to something someone says. You know it isn't the endlinks, he was just confirming.
We aren't english nerds, we are people who are trying to help you. We can more easily help you when we understand what you are saying. I think we are all having a hard time communicating with you. Replacing all new parts without diagnosing the problem doesn't always fix it, sometimes can make it worse, just ask behlinla for his opinion. Souza - please don't reply back to him. As to your alignment issue, no the CV joints shouldn't change alignment. I'd take it to someone that knows what they are doing personally, I'm at a loss to why this is happening.
#16 (permalink) | |
Cake monster
Member Number: 18214
Drives: none right now
#17 (permalink) | |
#18 (permalink) |
That's one weird emoji, LOL!
#19 (permalink) | |
Member Number: 4817
Drives: 1992 Taurus SHO
Rep Power: 15 ![]() |
92 White SHO ![]() -Performance: Turbo 297hp 279ftlb -Drivetrain: CM Clutch,SHONut Mounts,QUAIFE -Suspension: SS Coilovers, 24/26mm,Poly,Gen3,H-Brace, Subframe -Brakes: Cobra front, 11.6 rear -Looks: Sound System,Speedhut,Pilot Fogs,Clear Corners,Gen2 Console, CF Cowl Hood & Trunk http://www.shosource.com |
#20 (permalink) |
Member Number: 26241
Drives: 03 SES FFV
Rep Power: 4 ![]() |
The camber will change as you steer, the top of the strut is aft and inboard of the bottom of the strut - so you're not turning on an axis that's perfectly horizontal, so you can't expect it to keep camber as you turn on the axis of the strut.
The change in camber while steering is advantageous to keeping the contact patch of the tire correct based on the side load, this is by design, and it also helps reduce your turning radius slightly. Also, as you steer and the car is in motion, the spring will compress which will affect camber as well (negative camber on the side your steering away from. You stated that you replaced the springs - make sure you have the correct springs for the car - check the ride height against specs for the car. More than -2 degrees when the car is straight and level isn't likely going to straightened out completely by cutting the strut plates, and getting out to the limit once the plates are cut can cause problems with the spring/strut contacting the wheel well or the inner fender liner as the struts turn on their axis. |
