Squeaking and vibration - Taurus Car Club of America : Ford Taurus Forum
Old 11-20-2012, 08:54 AM   #1 (permalink)
Member Number: 46192
Drives: 2002 Taurus SEL
another_newfie is an unknown quantity at this point
Default Squeaking and vibration
This past weekend I replaced the rear shoes and wheel cynlinders on our 02 Taurus SEL. That all seems to be functioning fine.
While doing the job I also checked the front brakes, I popped the calipers off and examined the pads and there are lots of pad left on each side so they appear to be fine.
After buttoning everything up and driving it, we can hear a reasonably loud 'squeak' from the driver side front wheel. The squeaking sound speeds up as the car goes faster. If I hit the breaks (even somewhat gently) it stops right away. As soon as I release the brakes it starts again. I also noticed at highway speeds (right at 95km/h to 100km/h) if I take my foot off the throttle and coast the car bumps, I can't really tell if it coming from the front or not. The squeaking definitely is coming from the front though.
I'll pull the wheel tonight when I get home from work and see if I can determine what is going on, but in the meantime does anyone have any ideas as to the potential cause?
another_newfie is offline   Reply With Quote
Old 11-20-2012, 09:06 AM   #2 (permalink)
Member Number: 51168
Drives: 1999 Mercury Sable LS Wagon Torreador Red, 3.0L Vulcan V6 Ford Taurus fro
dbeach84 has a spectacular aura about
Had this happen on a different car and it was due to not greasing the caliper screws. By removing the calipers you've likely changed their position slightly. It could be that that now something, likely the edge of the pad, is now making contact with the rotor. Try removing and reinstalling the calipers again.
- 1999 Mercury Sable LS Wagon - 3.0l Vulcan -AX4N - Toreador Red on gray - Ford Taurus front end (salvage car) - 76K original miles
- 1997 Dodge Neon - 2.0L SOHC - Red w/ Silver rally stripes - Mildly upgraded - 270K miles and still going...
"The point is, you see, that there is no point in driving yourself mad trying to stop yourself going mad. You might just as well give in and save your sanity for later."
- Ford Prefect, from "Life, The Universe, and Everything" by Douglas Adams
dbeach84 is offline   Reply With Quote
Old 11-20-2012, 09:34 AM   #3 (permalink)
Thanks dbeach84, I appreciate the advice. I'll do that.
Old 11-20-2012, 08:16 PM   #4 (permalink)
Tonight I popped both fronts and had a look. Everything looks fine. I see no evidence of scraping, nor any evidence of any cause of the squeaking. Both the wife and I drove the car with windows open trying to locate the source of the squeak after buttoning it back up (yes it's still there) but we weren't able to 100% tell which wheel it is coming from.
We believe it's coming from the rears. Hard to tell though. Tomorrow night I'll pull both rears and take a peek.
Bloody annoying.
Old 11-21-2012, 10:51 AM   #5 (permalink)
Member Number: 31844
Drives: 2003 Duratec
maggie is on a distinguished road
Did you clean & regrease the caliper pins?
maggie is offline   Reply With Quote
Old 11-21-2012, 12:15 PM   #6 (permalink)
Yes I did.
This morning on the drive into work the car was silent. Despite after putting everything back together last night after checking the fronts again and the noise still being there. .
No idea at this point, I will double check the rears tonight to be 100% sure there is nothing re-assembled wrong.
Old 11-21-2012, 08:52 PM   #7 (permalink)
Well it appears it's all dealt with. I tore down the rears again tonight and while everything was all together properly, I hadn't tightened up the adjusters enough and I think there was too much slop in the drums. I believe they might have been rubbing. I also cleaned everything to within an inch of it's life with brake cleaner and buttoned it all up.
Still a little bit of a squeak, but the pedal is back to where it should be and for now I'll leave it be.
Old 12-02-2012, 03:22 PM   #8 (permalink)
Member Number: 43484
Drives: Taurus 2000 SES 12-valve
Architect is an unknown quantity at this point
The squaking is caused by the driving itself, right? Not by the car moving up and down, like you do with "testing" the shocks?
Architect is offline   Reply With Quote
Old 12-02-2012, 10:06 PM   #9 (permalink)
fct
Member Number: 10774
Drives: 1999 Duratec
I had exactly this problem after doing my last brake job. A kind of a rubbing/knocking noise coming from front right side as car gets moving at speeds of 20-45mph, but stops when I apply brakes. It turned out that there was nothing wrong with the brake job. The passenger wheel lug nuts werer not tight enough.
fct is offline   Reply With Quote
Old 12-04-2012, 11:37 AM   #10 (permalink)
It is definitely not a knocking type sounds, it's clearly a metal to metal squeaking. It also 100% stops as soon as you depress the brake pedal.
Lug nuts are torqued to spec, so it isn't that.
Architect, yes the squeaking happens when driving. It won't happen right away, the brakes have to heat up a little first.
It isn't getting worse according to the wife (it's her daily driver), nor is it getting much better either.
