Ball Joints and Ball Joint Tools - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Old 11-13-2012, 01:05 PM   #11 (permalink)
Member Number: 3575
sfhess will become famous soon enough
Some folks on here have had great success by just hitting things with a big hammer.
1969 Cougar XR 7 351W
2002 Ford Explorer XLT RWD 4.0
sfhess is offline   Reply With Quote
Old 11-13-2012, 09:29 PM   #12 (permalink)
sheila is just really nice
^ Somebody knows me, lmao!!!
Old 11-27-2012, 04:32 PM   #13 (permalink)
Member Number: 35134
Drives: 2004 Taurus SES 3.0l DOHC
Joe_K is an unknown quantity at this point
I didn't have too much trouble with the passenger side, the driver side was worse. I didn't have to loosen/lower the subframe any, but, a 5 foot piece of 1 inch pipe came in handy as a pry bar and helped that I had the strut/knuckle/ball joint all assembled prior to putting it in the car. Had someone sit on the end of the pipe and I was able to get the control arm just low enough to slide it in with a little coaxing.
Joe_K is offline   Reply With Quote
Old 11-27-2012, 06:15 PM   #14 (permalink)
Member Number: 47403
Drives: 2004 SES
Bob R is an unknown quantity at this point
Isn't it a pleasure that we have to resort to all these exotic ways of doing things just to perform maintenance on these Fix Or Repair Dailys?
That's because they have a better idea.
Bob R is offline   Reply With Quote
Old 11-28-2012, 03:46 PM   #15 (permalink)
Member Number: 13548
Drives: 99 SHO welded
liquid_force has a little shameless behaviour in the past
I've been able to get mine back in with just a 24" prybar. I've had the pass side apart once, and the driver's side twice.
I think the trick is DON'T put the knuckle pinch bolt back in the knuckle.
Slide the knuckle UP the strut tube as far as you can. I think there's 1/4" to 1/2" of slack there. That should provide the clearance for the LCA to clear the BJ stud, but it still takes quite a bit of downward force on the prybar.
99 SHO
  • Welded cams
  • 142k
  • sax delete
  • aux trans cooler
  • Front comps, 12" sub, 2 amps
liquid_force is offline   Reply With Quote
Old 12-08-2012, 06:22 PM   #16 (permalink)
Member Number: 43484
Drives: Taurus 2000 SES 12-valve
Architect is an unknown quantity at this point
The problem with installing the strut is that taking the suspension apart is NOT the reverse of putting it back together again.
Taking it apart you losen the balljoint from the control arm, lift the balljoint out of the control arm (pulling the knuckle up while pushing the control arm down with your foot) and then you pull the knuckle off the strut.
Putting it back together you first put the balljoint into the control arm and then wriggle the knuckle onto the strut.
Because there is very little room, the tension caused by the control arm makes reversing these procedures almost impossible.
Architect is offline   Reply With Quote
Old 12-08-2012, 06:59 PM   #17 (permalink)
Super Moderator
danhasenauer's Avatar
Member Number: 12182
Drives: a Taurus
danhasenauer has a spectacular aura about
Man, you guys are working too hard! The driver's side is the bitch side, and I lower the subframe a good inch or more. 2 big bolts, just loosen them up some, don't remove. Let it down easy with a hydraulic jack a little, and those parts all slide together easy. Joe K, if you needed a 5' pry bar, you did need to lower the subframe! I used to be a pry bar guy myself until the first time I lowered that stuff for clearance. I was amazed at how easy it is to do.
'96 LX DOHC Moonlight Blue
RIP 'Ol Blue - 09/2012
danhasenauer is offline   Reply With Quote
Old 12-29-2012, 08:27 PM   #18 (permalink)
Member Number: 51980
Drives: 2002 SES Sport DOHC
nbkcu33 is an unknown quantity at this point
Default Lowering the Subframe?!?
I am working on replacing the lower ball joint on my 2002 SES Sport drivers side. I have the new ball joint pressed in and everything is aligned but I can't get the LCA low enough to get the ball joint in the hole. I need about 3/4 of an inch. I am willing to try anything at this point. How exactly would I go about lowering the subframe?
nbkcu33 is offline   Reply With Quote
Old 01-01-2013, 05:49 PM   #19 (permalink)
Member Number: 28011
balochko24fan has a little shameless behaviour in the past
Wink ball joint
heres the easy way,just loosen the front attaching bolt of the lower control arm,it allowes the lower control arm to drop enoungh to put the ball joint stud back in,if for some reason it still dosent fit,remove strut pinch bolt and slide spindle up strunt for even more clearance.
balochko24fan is offline   Reply With Quote
