#121 (permalink) |
Member Number: 29661
Rep Power: 5 ![]() |
So what's the latest status?
I've had my car back after having all 4 corners changed. Positives: No noises from any corner Rear does not compress excessively when you sit in the rear Cornering and handling more confident and has improved noticeably Front end bouncing has gone. More composed over uneven freeways and other roads. This was the original complaint. Seems to be a little quieter and smoother Car tracks straight now. Had begun to pull strongly right after having had a small tendency to drift slightly left. I haven't done an alignment. Slight negatives: Still a little bit of front end movement when braking Front is higher than spec, so looks a little strange. And feels a little strange when sitting inside. But headlight aim has improved! Left rear sitting lower than right rear and is below spec. I suspect something else is at fault here because I measured this issue on the oem strut assemblies with which I otherwise had no complaint with. However, it was the out of spec measurement on the oem's that prompted me to change out the rears as well. Overall, I have a couple of other observations. The rear pinch bolts were changed but the old ones looked fine. This 2004 has always been in CA, 70k and garaged over the last 6 years. No noises or issues with other suspension components. Old strut assemblies are largely rust free. I think that the advice to change struts at 50k and to consider changing strut assemblies before you get to 100k is sound in that it prevents wear and damage to other components and tires. This car got to 70k before the front struts failed but I suspect my front tires wearing faster than expected might have been related to slowly wearing OEM struts. In general, this car has not had adults and / or excessive amounts of luggage in the rear, so I think that's why my rears were fine (my right rear was spot on the target ride height). However, I'm glad I've changed the rears out as the 4 struts seem to be working together well from a handling point of view, and the firmer rears seem to make sense for better ride and handling, as well as longevity of other suspension components. With the left rear sitting a little low, and the right rear pretty much on spec, the fact that the fronts sitting a little high, makes it look a little strange. But perhaps it will settle. At this point I give it an 8/10. Having purchased all 4 for $260 after rebate was a great result. It's also nice to know that there is a lifetime warranty on the strut assemblies. |
#122 (permalink) |
![]() Member Number: 49890
Same status for me! Haven't had the chance to replace the drivers side link yet so the sway bar just kinda clatters around over big bumps, but besides that my knocking noise is gone!
I agree with you that the front end sits higher. I have also known the headlight aim has improved. After an alignment my car drives perfectly. I don't think I have the problem of one end sitting lower than the other, was the car ever in an accident?
#123 (permalink) |
I've owned the Taurus since it was 1 year old. No accidents since then and no accident disclosed to me by Hertz.
#124 (permalink) |
So I finally replaced both of my sway bar links. I replaced one two weeks ago, then the second one I got was bad out of the box. Returned it, but they didn't have a replacement. So I got another one the other day and installed it.
Today I was driving along and lo and behold the passenger side starts clanking again. I'm going to make sure that it didn't just come loose. Going to piss me off if it already is bad!
#125 (permalink) |
Member Number: 85
Rep Power: 13 ![]() |
What brand did you get?
2000 Duratec SE White Wagon <span style="font-family:Optima">Voom: FPS X-Cal2 |
#126 (permalink) |
Duralast lol, cheapest one. I didn't have any extra cash a few weeks ago when I got the first one. My guess is it just came loose at the strut tower.
It has a lifetime warranty though.... So I get a new one free if it did already go bad!
#127 (permalink) |
Member Number: 1771
Drives: 97 SHO Sedan, 00 SEL Sedan
With a few exceptions, for suspension related components, I try to give my business to Moog, especially their ProblemSolver line.
It's not the cheapeast, but it's the most reliable and durable product on the market normally. I would return the junk to autozone and drop the difference in coin on some Moog greaseable endlinks...or get some OEM/TRW plastic endlinks. I don't like doing work multiple times over because of poor product quality.
--Nick M. | Blythewood, SC | AAP/Atlanta Built Bulls -Silver Frost MC 2000 Ford Taurus SEL | DOHC/AX4N | 184K -Toreador Red MC 1997 Ford Taurus SHO | DOHC/AX4N | 149K --Wood paneled 1991 Mercury Grand Marquis LS Colony Park wagon | OHV/AOD | 180K ish? Sold.... --Driftwood MC 1987 Ford Taurus GL Wagon | OHV/AXOD | 254K - now owned by major!! Scrapped... --Sand Beige 1987 Ford Taurus GL |197K | OHV/AXOD |
#128 (permalink) |
I know what you mean nick. I'll think about it.
#129 (permalink) |
Member Number: 85
If you get a warrenty replacement, see if you can pay the difference and get moog/ trw or oem.
There is a reason why everyone calls it duracrap.
#130 (permalink) |
Well I know. I've had some good duralast stuff and bad. The ONLY one autozone sells is duralast, so I'm screwed.
