Torque Spec for Top Bolts and Pinch Bolts on Rear Struts - Taurus Car Club of America : Ford Taurus Forum
post #1 of 20 (permalink) Old 08-21-2012, 11:13 PM Thread Starter
Can someone please give me the spec for the top mounting bolts and the pinch bolt on rear struts for a 2004 SES?
I found 22 and 59 ft pounds on a 2006 doing a search of the forum. Is this good for a 2004?
Bob R is offline
post #2 of 20 (permalink) Old 08-22-2012, 01:55 AM
From the 2004 specification book:
Wheel spindle pinch bolt: 59 lb-ft
Strut and spring upper mount-to-body nut: 22 lb-ft
So yes, they are the same as you would expect.
behlinla is offline
post #3 of 20 (permalink) Old 08-22-2012, 06:52 AM Thread Starter
Thank you.
Bob R is offline
post #4 of 20 (permalink) Old 08-26-2012, 08:06 PM Thread Starter
If the pinch bolt comes out in one piece, do you have to drill the existing holes out to a larger size to use a 7/16 grade 8 bolt instead of a new pinch bolt or will it fit through the existing holes?? How long does the 7/16 bolt have to be for the rear struts?
Bob R is offline
post #5 of 20 (permalink) Old 08-26-2012, 10:52 PM
2.5".
post #6 of 20 (permalink) Old 08-27-2012, 09:32 AM Thread Starter
2.5".
Thanks Sheila.....and if the pinch bolt comes out in one piece, will the grade 8 bolt fit through the holes or will I have to drill it out larger for the grade 8 to fit?
Bob R is offline
post #7 of 20 (permalink) Old 08-27-2012, 11:23 AM
Bob, I honestly can't remember if I had to waller out the hole a bit or not. Hell, knowing me, if it was too small I may have went with a 3/8" grade#8 bolt 2-3" long with a matching nyloc (plastic insert) lock nut, lol. Also, if the pinch bolt came out in 1 piece, I may have slathered it in never-seize and reused it if not damaged to avoid a trip to the hardware or parts store.
post #8 of 20 (permalink) Old 08-27-2012, 12:00 PM Thread Starter
OK Thanks Sheila. I bought a couple new pinch bolts so maybe I'll mic their diameter to see what they are.
I was just going to replace the old with the new ones, but I figured, hell...if the bolts just slide right in, why not. I don't have a 1/2" drill to drill anything bigger than 3/8"
Every time I go to start this job, something comes up where I need the car and can't afford to have it sitting there with a broken off pinch bolt. I've been spraying it every other day with PB hoping it's working its way in.
I know this is not a difficult job, but I am dreading it. Hopefully when it's done, I'll sit back and say...."That wasn't that bad".
Thanks for your help, Sheila.
Bob R is offline
post #9 of 20 (permalink) Old 08-27-2012, 12:03 PM
Heat and lube, lol.
post #10 of 20 (permalink) Old 08-27-2012, 12:23 PM Thread Starter
I mic'd a new pinch bolt neck and it was .424" so I guess that answers that question. I doubt if the holes have .075" clearance.
Bob R is offline
