Alignment Specs - Taurus Car Club of America : Ford Taurus Forum
post #1 of 1 (permalink) Old 07-29-2009, 09:46 AM Thread Starter
Here are the spec's straight from Ford shop manual..
Alignment Specifications Item LH RH Total/ Split
Front
Camber -0.5° ± 0.6° -0.5° ± 0.6° 0° ± 0.7°
Caster 3.8° ± 1.0° 3.8° ± 1.0° 0° ± 0.85°
Toe (positive value is toe-in, negative value is toe-out) - - -0.20° ± 0.25°
Rear (Four Door)
Camber -1.0° ± 0.7° -1.0° ± 0.7° 0° ± 1.2°
Caster - - -
Toe (positive value is toe-in, negative value is toe-out) 0.18° ± 0.20° 0.18° ± 0.20° 0.36° ± 0.25°
Rear (Wagon)
Camber -0.6° ± 0.7° -0.6° ± 0.7° 0° ± 1.2°
Caster - - -
General Specifications Item Specification
Front Ride Height
4-Door 713.3 mm ± 10 mm
(28.08 in ± 0.19 in)
Wagon 710.4 mm ± 10 mm
(27.96 in ± 0.19 in)
Rear Ride Height
4-Door 696.3 mm ± 10 mm
(27.41 in ± 0.19 in)
Wagon 702.8 mm ± 10 mm
(27.66 in ± 0.19 in)
Ball Joint Deflection
Lower 0-0.8 mm (0-0.032 in)
Torque Specifications Description Nm lb-ft
Front subframe mounting bolts 103 76
Tie-rod jam nuts 55 41
Upper strut mounting nuts 35 26
Rear control arm in board mounting nut (4-door) 80 59
Rear control arm to spindle nut (station wagon) 80 59
jsutton02 is offline
