Battery Light Flashing - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #1 of 13 (permalink) Old 08-15-2016, 02:27 AM Thread Starter
Post Battery Light Flashing
Hi I need some help, on my 99 been having a issue where the battery will discharge over a couple of days if I leave the car sit, I replaced the battery and when I checked voltage at idle was around 12.9 volts on new battery but it still goes dead over a couple of days if I don't drive. When I have tried to start and have to use my little portable booster starter I notice the cables are kinda hot, I can see one section of ground on fender is clean no corrosion. Also what I notice is the Theft light flashing and tonight I noticed the battery light flashing with the car off just sitting. This is a California car but has been with me in Michigan and now Indiana last four winters. I appreciate any and all help. Thanks
Jriver309 is offline
post #2 of 13 (permalink) Old 08-15-2016, 04:40 AM
ice445's Avatar
Possibly a bad alternator diode that's shorted open and pulling current. Try disconnecting the alternator output cable from the stud and see if the problem stops. 12.9 is also way too low of a reading at idle (should be getting 14V), so it's very likely that the alt is bad.
Michele likes this.
ice445 is offline
post #3 of 13 (permalink) Old 08-15-2016, 10:45 AM
Cassette stuck in the player?
post #4 of 13 (permalink) Old 08-15-2016, 10:53 AM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
From the Solutions to Common Problems forum:
Battery Draw Testing
jag1959 is offline
post #5 of 13 (permalink) Old 08-15-2016, 10:54 AM
Likely two issues at one time. Battery going down due to something being on or a bad Alt. Volts idling with things off should be 14.2-14.4 when first started. Should hold this with the headlights added with little to no change.
post #6 of 13 (permalink) Old 08-16-2016, 11:05 PM Thread Starter
Well this has taken a further twist, the light is on now all the time with the car off, but the car will not start, the starter does nothing, no clicking nothing. the battery is fully charged I used my charger on it. wondering if I have a combination of issues at same time now
post #7 of 13 (permalink) Old 08-16-2016, 11:41 PM Thread Starter
Great video thank you that was something I needed to learn about
post #8 of 13 (permalink) Old 09-01-2016, 04:59 PM Thread Starter
Wanted to update, been out of the country for work and back to the car. I got the car to start by jumping the starter relay after the theft light would not stop flashing so I swapped relays it runs but battery light still on when car is off, a neighbor heling said there is a recall for this for the ignition switch, anyone hear of this before?? And also how do I disable the anti theft module
post #9 of 13 (permalink) Old 09-08-2016, 01:18 PM Thread Starter
Still looking for help on this
post #10 of 13 (permalink) Old 09-08-2016, 02:05 PM
Exalted Grand Poobah
Lgbpop's Avatar
Year: 1990
You don't disable the antitheft system, it's too fully integrated into the car's electrical system. I've seen them flash before in Fords with insufficient start voltage.Also, leaving a new battery hooked up when your car is in this condition is gonna ruin a perfectly-good battery. Call Ford about recalls: I never heard of this one myself.
Have you had that alternator tested yet?
Lgbpop is online now
200 Ford Taurus SES U Engine, Battery Light Saga connordo Maintenance and Repair 0 07-08-2015 08:30 PM
Check Engine light: Check the battery! Brcobrem Maintenance and Repair 10 07-16-2014 03:00 PM
Battery Light on ohio_grad_06 Maintenance and Repair 22 05-27-2014 09:29 PM
Help Please Battery Light, High RPMs, Stalls TheBassMekanik Maintenance and Repair 5 11-05-2013 11:15 PM
URGENT! Battery light ON = charging?? tripslipfall Maintenance and Repair 15 07-10-2013 06:01 PM
