Trouble with starting. No crank. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 12-15-2013, 01:15 PM Thread Starter
Question Trouble with starting. No crank.
Hi! This is my first post and I am having trouble with my car. I bought this used 1993 Ford Taurus 3.8 liter v6. It has be having problems I think with the ignition switch. sometimes it wont turn over at all. you turn the key and hear the fuel pump and turn the key and NOTHING. No sounds at all, if you continue to turn the key several time it will finally start. But today it has decided that it just isn't going to do anything. First thing this morning it started fine and went to the store and it wouldn't do anything when I came out. It is sitting at the store right now. I am at a loss. It won't make a sound at all like it is trying to start. I am getting power to the switch it just isn't going on to the engine. It has a new battery and new cables. Please if you have any ideas, I could really use your help.
Kghow2000 is offline
post #2 of 5 (permalink) Old 12-15-2013, 01:26 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Jump the solenoid. Run a jumper direct from Batt+ to S (small) terminal on solenoid. Make solenoid connection 1st. That should get you home
jag1959 is offline
post #3 of 5 (permalink) Old 12-15-2013, 01:34 PM Thread Starter
Ok Thanks I am going to try this I will let you know if I make it home.
post #4 of 5 (permalink) Old 12-15-2013, 02:47 PM Thread Starter
well I am home with the car now. My Uncle came by and tried to jump it. and it just sparked. Didn't turn. But he tapped the starter and it fired right up. SOOO I guess I am buying a new starter. Thanks for your help.
post #5 of 5 (permalink) Old 12-15-2013, 03:02 PM
jag1959's Avatar
Glad to here you got it home. Starter is more expensive than a wiring issue but a simpler fix
jag1959 is offline
2002 SES 3.0L,158k, cold starting problem Shawn Maintenance and Repair 3 11-19-2013 09:45 PM
2003 Taurus starting issues Toawk Maintenance and Repair 1 08-01-2013 09:16 AM
keep going through crank position sensors Pepsimax5454@yahoo.com Maintenance and Repair 4 06-23-2013 02:59 AM
Intermittent (now permanent) No Crank, No Start Peter F Maintenance and Repair 3 05-10-2013 12:05 PM
Why won’t my car start? - Comprehensive No-Start Troubleshooting Guide behlinla Maintenance and Repair 1 01-06-2013 12:52 AM
