Factory Alarm - Taurus Car Club of America : Ford Taurus Forum
post #1 of 9 (permalink) Old 01-27-2013, 09:19 PM Thread Starter
ringo234's Avatar
Factory Alarm
I bought my 2003 Sable on Easter 2012. It has keypad for the doors and a factory alarm with keyless entry. I found the Master key-code.
My question is after I enter the key-code will the factory remote start working the factory alarm or is there something else I need to know.
Every once in a while the factory alarm will go off and the only way to stop it is by putting a key in the door and unlocking it. I know it's a factory alarm because of the flashing red light on the dash panel.
I also had an after market alarm installed.
I hope this clear enough for someone to point me in right direction to get the remote to control the alarm and keyless entry.
Thanks Andy
ringo234 is offline
post #2 of 9 (permalink) Old 01-27-2013, 09:21 PM
Entering a valid code will stop an alarm in progress, as will pressing the unlock button on a fob or putting the key in the ignition and turning it to ON.
behlinla is offline
post #3 of 9 (permalink) Old 01-27-2013, 10:21 PM Thread Starter
ringo234's Avatar
The remote I got with the car has never done anything when pushed.
I was hoping resetting the door code would fix that but maybe not.
ringo234 is offline
post #4 of 9 (permalink) Old 01-28-2013, 12:00 PM
Factory Alarm
Have you changed the battery in the fob?
Sent from AutoGuide.com App
bmwides is offline
post #5 of 9 (permalink) Old 01-28-2013, 12:13 PM
^+1. Check/replace fob batt. Reprogram fob (remote) per owners manual instructions.
post #6 of 9 (permalink) Old 01-28-2013, 09:09 PM Thread Starter
ringo234's Avatar
Yeah, the first thing I tried I wish it was that easy. I never heard the term FOB before.
ringo234 is offline
post #7 of 9 (permalink) Old 01-30-2013, 10:57 AM
belcher08's Avatar
Send a message via Skype™ to belcher08
Reprogram it. Super simple to do. Turn the key from Off to On (NOT START) 8 times. The locks will cycle when the car is in programming mode. Press any button on the fob (keyless entry remote, dongle, whatchamagoozer... you get the idea... it has many names). Voila! You have a programmed remote. If that doesn't program it, the factory alarm is enabled by grounding a wire on a connector that goes to the GEM. (Power to wire = No alarm... weird right?) I don't remember which wire it was, but I know it works because I grounded it and gained the factory alarm. Someone had a write up about it. Try searching perimeter alarm. It was a thread from back in March. So basically if you want to kill the factory alarm, hook that wire to 12v and it should disable it... thus preventing the alarm from going off.
You also said you had an aftermarket alarm installed, why did the installer not disable the factory alarm? Aftermarket and factory alarms usually don't play well together.
Tyler
2001 Taurus SES Vulcan (Toreador Red) "Taurusaurus Rex" - Traded on 08/15/2013
2009 Kia Rio LX 1.6L CVVT (Silver Frost) "The Econobox"
belcher08 is offline
post #8 of 9 (permalink) Old 01-31-2013, 02:24 PM Thread Starter
ringo234's Avatar
It did the above the door locks cycled as above. I pressed a button on the FOB and nothing. I think maybe it's been disabled. I did replace the battery. Oh well I do have a better after market paging alarm/remote/fob
ringo234 is offline
post #9 of 9 (permalink) Old 01-31-2013, 09:15 PM
It could be the FOB you have is not correct for your generation of Remote Keyless Entry. Not all FOBs are alike.
ctubutis is offline
