Member Number: 52026
Drives: 1997 Taurus LX
Hello,
I am new to the board and tried to find the information I need before I asked. I have the 97LX with the Mach audio amp/hu. I need to know what impedance my amp uses. My two lower front door speakers are blown and I am looking at replacing them with a set of pioneer 3 way 4 ohm speakers. This is where I am worried... the Mach system has the separate tweeters at the top of the door. Can you tell me if the tweeters are wired independently of the lower door speaker or are they wired in series or parallel? This is why I need to know if the amp is meant for 2 or 4 ohms speakers. If they are connected in parallel, then that means the tweeter and lower speaker are both 4ohms that turn into 2ohm resistance. I hope I didn't come across as confusing. Any help will be appreciated. Thanks in advance! |
#2 (permalink) | |
Member Number: 49973
Drives: 1999 Taurus wagon se 24v dohc 169,000 miles
Well, I do a lot of home audio and I know that impedance is incredibly important. For example... If you have an amp that is rated at 8 ohm but you use a 4 ohm speaker you end up taxiing the amp to the point of blowing it because the speaker is only providing half of the impedance necessary.
But, if the tweeter is wired separately then there is nothing to worry about. Does anyone happen to have a wiring diagram of this sound system? Thanks |
#5 (permalink) | |
Here's the diagram: http://www.revbase.com/BBBMotor/Wd/D...3-ec5a80b6b47a
The sail speakers are wired in parallel as you can see. This would change the characteristic impedance of the circuit if the two speakers are different impedances. I think the speakers are 4Ω. You could probably test the other speakers to make sure. |
So with the tweeter and lower speaker wired together does this mean that my amp is 2 ohm or 4 ohm?
Remember, it's the Mach amp/hu. Thanks |
Two 4Ω loads in parallel is an equivalent resistance of 2Ω. The front channels of the MACH RCU might have been designed for this lower impedance, or the impedance of the sail tweeters might be higher. Can you measure them with a DMM?
#9 (permalink) |
I will try tomorrow. I have yet to open the door panel. I wish I could find a spec sheet of the Mach amp so I could know for sure whether it's rated for 2 or 4 ohm or both. I will let you know ASAP tomorrow.
Thanks again for the help |
