04 all power windows dont work - Taurus Car Club of America : Ford Taurus Forum
Old 01-27-2012, 06:33 AM   #1 (permalink)
Member Number: 45242
Drives: 2004 wagon, 6
joefloyd is an unknown quantity at this point
Default 04 all power windows dont work
I hope some one can help with problem. All my power windows and switches stop working at the same time. If I try them 2 to 5 days later they all work.
What can the problem be ?????
Thanks Joe floyd
joefloyd is offline   Reply With Quote
Old 01-27-2012, 08:00 AM   #2 (permalink)
Member Number: 33869
Loose connection or bad switch or relay. All control pads or just the drivers control pad?? By pad I mean the window controls on each door. Any moisture when it happened like a car wash or big puddle, driving rain,etc??
Old 01-27-2012, 08:09 AM   #3 (permalink)
I checked the conections at the drivers door and they are all ok. All 4 control pads dont work. Today it started working and it is raining hard.
The problem corects it self for 2 to 5 days and then it stops working.
This has happend for the last Month. I can not understand how it corrects itself.
Old 01-27-2012, 08:20 AM   #4 (permalink)
One day it won't. Check you GEM module that is part of the main fuse panel inside the drivers side fire wall. The window relay and controls are from this panel. Ask the dealer for a copy of the wiring for your windows. It is a trial and error hunt with a meter and some luck. Connections should be checked with a meter for the voltage you need at each wire. I would suspect the main drivers side switch if the others are not working either. You could have a loose ground wire at the fuse box location. There are a lot of critical grounding locations in the car. Some in trunk, some in cab and some in engine bay. I would suspect a ground or a bare spot on a wire through the door as a possibility.
Old 01-27-2012, 09:26 AM   #5 (permalink)
Thank you for your help, I will check with ford on that and I will ask them if this is a comon problem. They may have some feed back on . Let you klow how I make out.
Thanks. Joe floyd
Old 01-27-2012, 11:06 AM   #6 (permalink)
Member Number: 5295
Check for a broken wire in the harness between the door and the body of the car. Wires are known for breaking from the flexing that occurs every time the door is opened and closed. Happened to me with lock out switch circuit.
