2001 taurus.. theft ligh flashing... car wont crank - Taurus Car Club of America : Ford Taurus Forum
post #1 of 17 (permalink) Old 06-04-2011, 03:16 PM Thread Starter
Hey everyone!
I thought the problem was the starter on my car. I had a mechanic come over and he bypassed the car to where it would actually crank over. My battery is fine, the radio turns on the lights come on and the windows will roll down. Can someone please help me figure out a way to bypass to where my car will start permanently? Is there a code I may enter to make it crank. I have been without a car for a week due to this and do not have money to call a tow truck so they can take it to a dealership that will upcharge me. Please.. Please.. Help! Thank you.
sgilluly is offline
post #2 of 17 (permalink) Old 06-04-2011, 03:38 PM
Bigdogg2830's Avatar
sounds like you have a bad pats. try locking you car with the fob and then using you key to unlock and see if that will help ( it does on some not all )
Bigdogg2830 is offline
post #3 of 17 (permalink) Old 06-04-2011, 03:54 PM
qwertz9586's Avatar
Sometimes moving the tilt steering to a different position may help. Try it on all the different positions.
qwertz9586 is offline
post #4 of 17 (permalink) Old 06-04-2011, 03:57 PM
ohhhh i forgot that one qwertz.
post #5 of 17 (permalink) Old 06-04-2011, 10:43 PM Thread Starter
Thanks for the reply. I will try that. However I forgot to mention the fact that my driver side lock near the handle seems to be jammed in and I cannot manage to lock or unlock my car from that side.
sgilluly is offline
post #6 of 17 (permalink) Old 06-04-2011, 10:45 PM Thread Starter
Ok I am heading out now to give it a shot thanks.
So I went outside and moved my steering wheel to all different places and the damn thing got jammed on me. Is this a security issue to where it locks up?
sgilluly is offline
post #7 of 17 (permalink) Old 06-05-2011, 03:49 AM
i would spray so lube into the lock on the door and let it sit. do nt force the key but wiggle it and turn back and forth. keep spraying and wiggling and it should free up. the tilt is stuck? ive only seen that happen once. it was from using the wheel to pull yourself up. it chipped a tooth and gummed up the works. is the wheel in the lock postion? if it is turn to relieve pressure and hope it works. just wondering have you only tried one key?
post #8 of 17 (permalink) Old 06-05-2011, 10:46 AM
qwertz9586's Avatar
It's not supposed to jam up. That is not a security feature. That's a mechanical issue with the steering column. Here's how to remove the column shroud to see what's jamming:
How To: Removing Column Shifter
post #9 of 17 (permalink) Old 06-05-2011, 11:36 AM Thread Starter
I most likely locked it by accident. And yes, since I have had this car I have only used one key on it.
In regards to my original post I still have not found a way to bypass the system to where my car would turn over. I still have faith that someone has a solution that can permanently let me turn my car on. I have tried moving the steering wheel, locking and unlocking with the fob and manually unlocking my car through the passenger side in addition to also having my starter tested. As im sure all of you can relate, the last resort would be to have my car towed and taken to a dealership where I can be upcharged.
sgilluly is offline
post #10 of 17 (permalink) Old 06-05-2011, 12:15 PM
Roach's Avatar
This may be a long shot, if it is something to do with your security, you may be able to reset it by unhooking your battery for about an hour.
Edit: Unless it's mechanically locked up where you can't even turn the wheel.
2000 Taurus SE "Lady Hearse"
__1995 Taurus SHO "Organ Donor"
____1996 Thunderbird LX "Jade Phoenix"
Roach is offline
