Rear Defrost Relay - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 11-21-2009, 04:20 PM Thread Starter
Vee
I have a 2000 Taurus SE-S with Duratec. My rear defrost is not working. I do have an aftermarket Metra kit for the HU. My rear defrost recently stopped working. No light on the button and no click from the dash.
I can't seem to get the relay to make that click noise when I press the button. I am trying to figure out if the relay itself is faulty.
I tied a wire into Relay Pin #85 & #86. I hooked up the multimeter and I had 3mV steady as well as .03mA. I also got a 92Ohm reading.
Then I tied a wire to Relay Pin 30 & 87. I got 13.84V and 3.39 mA. 0 Ohms. The readings were slightly lower when I turned the car off.
When I tied 30 & 87A there were no discernible differences between 87 and 87a.
Are these readings normal? ARe there other tests I need to run?
Nothing happened to the readings when I pressed the defrost button.
Thanks for any help!
Vee is offline
post #2 of 5 (permalink) Old 11-21-2009, 08:07 PM
Send a message via MSN to goodbrosuit
pull the relay out and get a 9 volt battery. look at the relay and you'll see a diagram of the insides and the pins are numbered. use an ohmmeter over the two switch pins and put the 9 volt over the two coil pins. should read near 0 - .1 ohms. and you'll feel/hear it click.
goodbrosuit is offline
post #3 of 5 (permalink) Old 11-22-2009, 12:22 PM Thread Starter
Vee
Thanks a lot! The relay seems to work just fine. (It clicks, and I got a .1 Ohm reading)
That sucks, because I was hoping I'd have an easy fix for my problem.
Vee is offline
post #4 of 5 (permalink) Old 11-22-2009, 01:28 PM
I can only assume you checked fuses, but if not, fuse 232 10amps, fuse 207 40amps, fuse 212 10amp. You have to have all for the circuit to work.
post #5 of 5 (permalink) Old 11-23-2009, 08:54 AM Thread Starter
Vee
Ive only checked two of those fuses...where is the other 10amp?
According to my manual,
Fuse #7 is the 40 amp Rear Defrost Grid Feed.
Fuse #12 is the 10 amp heated mirrors and Rear Defrost Switch.
Fuse Position #9 is the relay itself.
Where is the other 10 amp fuse? (I'm assuming #207 is the 40amp and 212 is the 10amp mentioned above. My fuse position #32 is ABS, DRL Relay Coil, Speed Control Actuator, Traction Control Switch, AC Heater Selector Swicth, Blend Door Actuator, Brake Shift Interlock
Vee is offline
