Generic Electronic Module - Taurus Car Club of America : Ford Taurus Forum
Old 07-04-2009, 11:52 AM   #1 (permalink)
Member Number: 20652
redlotus50 has a little shameless behaviour in the past
My car is making clicking sounds when I am driving, when this happens my power windows stop working as does my windshield wipers.My powersteering also gets real stiif and is haed to turn and then will suddenly release. I have been told by a mechanic that my GEM is going out and I need to replace it, has anyone else had this problem? Is this whats really wrong?
redlotus50 is offline   Reply With Quote
Old 07-04-2009, 08:27 PM   #2 (permalink)
fdogg96's Avatar
Member Number: 11956
Drives: 1995 Gen 2 yo!
fdogg96 has a little shameless behaviour in the past
Wrong section.
Clubs: TCCA-WEST COAST and SHO-CAL
fdogg96 is offline   Reply With Quote
Old 07-04-2009, 10:44 PM   #3 (permalink)
Member Number: 4670
ldheinz has a little shameless behaviour in the past
QUOTE (Terrible T @ Jul 4 2009, 11:52 AM)
My car is making clicking sounds when I am driving, when this happens my power windows stop working as does my windshield wipers.My powersteering also gets real stiif and is haed to turn and then will suddenly release. I have been told by a mechanic that my GEM is going out and I need to replace it, has anyone else had this problem? Is this whats really wrong?[/b]
Clicking sounds usually mean relays. Try pulling each relay and cleaning the contacts with WD-40 or similar. It might help.
'96 Taurus LX Sedan, Duratec, dual exhaust, MagnaFlow Y-Pipe, 4-wheel discs with Cross-Drilled Front/Rear Rotors, SHO front brake upgrade with Wagner ThermoQuiet Pads, Kumho Ecsta ASX 215/55R16 93W Tires on Ford SVT Cobra 16x6.5 5-spoke wheels, 38 PSI of Nitrogen, Gabriel Ultra Struts, SHO Rear Springs, SHO 150 mph speedometer, PST Polygraphite Sway Bar Bushings, stronger front/rear end links, E3 Plugs, Accel SuperCoil, K&N panel filter, JST Rear Wing, SilverStar Ultra headlights, Wired-in Radar/Laser Detector, JBL sound with upgraded speakers all around including subwoofer, 1/2 Farad Capacitor on Upgraded JBL Amp to 35Wx4, upgraded dash to cassette w/CD changer controls and climate control, added rear CD changer to Ford system, leather interior, factory alarm, keyless entry, chipped key, LED interior lights. 35.6 mpg highway at 68 mph with A/C on.
ldheinz is offline   Reply With Quote
Old 07-05-2009, 09:15 AM   #4 (permalink)
Member Number: 16800
thesavo has a little shameless behaviour in the past
IF you are going to go though the process of cleaning the relay contacts. Best get the right tool.
$3-4 any automotive store.
http://www.crcindustries.com/auto/content/...N=05101&S=N This will do a much better Job than WD-40 or the similar.
I would not jump for a new GEM just yet. Last I new Power steering was a mechanical device.
Could be a device on your Serpentine belt seizing. Like your alternator. Which would mean that your electronic devices are not getting enough Voltage and the coils of the relays are "collapsing". Meaning they do not have enough voltage to sustain.
Check your serpentine belt. Have your alternator tested.
Also: Is there a mod that can move this to Maintenance and Repair
thesavo is offline   Reply With Quote
Old 07-07-2009, 08:52 PM   #5 (permalink)
QUOTE (thesavo @ Jul 5 2009, 09:15 AM)
Also: Is there a mod that can move this to Maintenance and Repair[/b]
Electronics. works too
Old 07-07-2009, 08:53 PM   #6 (permalink)
QUOTE (outatyme @ Jul 5 2009, 10:11 AM)
He must have VAPS (Variable Assist Power Steering) (My 1997 GL w/ vulcan + AX4N does)
If I unplug my GEM the steering gets extremely stiff!
All the symptoms he posted sound like a bad GEM (or bad / loose wiring to the GEM)
Your mechanic seems to know what he's talking about on this one.
I would check the connections to the GEM (three wire connectors BIG, SMALL, BIG)
Grey in color that hook to the bottom of the fuse box located at the drivers feet
(area of the parking brake / normal brake pedal up under the dash is where the junction
box with GEM strapped behind it is) The three connectors to it are right at floorline and
could get stepped on and be loose or get stripped insulation from peoples feet.
please list all the symptoms you have going on in relation to this and I will attempt to help
you track it down![/b]
No Way! That's cool. I need to add that to the list.
