Tap Into Left/right Turn Signals - Taurus Car Club of America : Ford Taurus Forum
post #1 of 10 (permalink) Old 06-01-2009, 10:11 AM Thread Starter
Jh8909's Avatar
I just recently bought an aftermarket LED third brake light and it has turn signal and hazard capabilities. I need to know where is the best spot to tap into the signal wires. Also the brake light has an extra wire dedicated for hazard capabilities but i was thinking that if the hazards are just both signals going at the same time then just hooking them up to the left/right turn signals would work.
95 Green/Green SLO, 185k, DD <-- FOR SALE!!!
92 Black/Black SHO, 148k, weekend car
Jh8909 is offline
post #2 of 10 (permalink) Old 06-01-2009, 11:03 PM
qwertz9586's Avatar
I wouldn&#39;t recommend using turn signals for the third brake light. It&#39;s designed to be a brake light only and if it doesn&#39;t function like it&#39;s suppose to then you could be denied insurance coverage in an accident. It can also cause your turn signals to flash super fast.
Anyways, on the G2, there is no dedicated turn signal wire in the back. The brake and turn signal are transmitted on the same wire.The brake light wiring goes through the brake on-off switch at the brake pedal to the multi-function switch (turn signal lever) and then goes to the taillight. When you activate the turn signal, the brake light signal from the brake light switch on the brake pedal is interrupted at the MFS and the MFS sends a flashing signal to the light in the back. If you use the wiring in the back, then your third brake light will act just light the stock taillights.
qwertz9586 is offline
post #3 of 10 (permalink) Old 06-01-2009, 11:53 PM Thread Starter
Jh8909's Avatar
alright well i hooked it up.. and i did end up tapping off of the left and right tail light turn signals. as of right now it works perfect! no hyper flashing or anything. i tapped into the greenish wire with a red stripe on each side. but the only problem i have now is that the signals work only when the brake light is not applied. the brake light overtakes the turn signals. i would really like the turn signals to flash when the brake is applied but i do not know how to do that. any ideas would be nice
Jh8909 is offline
post #4 of 10 (permalink) Old 06-02-2009, 12:03 AM
qwertz9586's Avatar
It could be a design of the unit itself (which goes back to my statement about the third brake light being a brake light only). The stock programming is that the turn signals override the brake lights.
post #5 of 10 (permalink) Old 06-02-2009, 01:09 AM
There is a terminal on the MFS that will allow the turn signals to act as brake lights EXCEPT when the turn signal is used. Then the side the turn signal is on will act like the turn signal.
post #6 of 10 (permalink) Old 06-02-2009, 03:47 PM
s2knott's Avatar
where can i do this on gen 4 in the front? i have led mirror puddle lamps that i want to be on with the signals and flash with them.
s2knott is offline
post #7 of 10 (permalink) Old 06-02-2009, 11:15 PM
qwertz9586's Avatar
QUOTE (s2knott @ Jun 2 2009, 12:47 PM)
where can i do this on gen 4 in the front? i have led mirror puddle lamps that i want to be on with the signals and flash with them.[/b]
There&#39;s a dedicated turn signal wire going to the front turn signals. Tap into that.
post #8 of 10 (permalink) Old 05-04-2010, 04:22 PM
s2knott's Avatar
just searching trying to find the wire that your talking about, i actually dont want the turn signal wire anymore id just like to find a hot headlight/running light wire so i can add some leds that only come on when the headlights are on, where can i tap into one in the drivers footwell?
s2knott is offline
post #9 of 10 (permalink) Old 05-04-2010, 07:36 PM
Don't Be Stupid
Just get it behind the headlight switch
00tec-satx is offline
post #10 of 10 (permalink) Old 06-01-2010, 06:02 AM
SurHaxalot's Avatar
Send a message via MSN to SurHaxalot
Talking
yes use that one !!!
its what i used for my sequential mod
QUOTE (Qwertz9586 @ Jun 2 2009, 08:15 PM)
QUOTE (Racer X @ Apr 20 2003, 11:27 PM)
- Step Ten.
Change your whole latitude with an ice cold Corona. You can substitute your Corona with the beer of your choice.
SurHaxalot is offline
