High Beam Indicator - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 05-16-2008, 05:30 PM Thread Starter
no1hedberg's Avatar
The high beam indicator stopped working on my '97 SHO. It actually began working periodically, but very rarely. I thought at first there was a short in the high beam switch, but I tried wiggling the switch, and it doesn't make a difference. Before I pull the dash apart, is it probably the indicator bulb? Is it wise to replace all the illumination bulbs in the gauge cluster while its apart? Thanks.
1997 Taurus SHO
Got Bull?
no1hedberg is offline
post #2 of 8 (permalink) Old 05-16-2008, 05:59 PM
Trader Score: 7 reviews
It's really easy to replace the bulbs in your floor shift SHO. And I highly recommend replacing all the backlight bulbs if one or more are out. You could go ahead and do the other bulbs while you're in there. Beats having to do the job twice right?
Here are the instructions: http://www.taurusclub.com/wiki/index.php/1...r_Shift_Only%29
Take some needle nose plyers, and twist counterclockwise to remove the socket, then pull up. Make sure you keep your fingers off the bulb glass
--Nick
bull geek is offline
post #3 of 8 (permalink) Old 05-16-2008, 07:12 PM
qwertz9586's Avatar
If it's a regular wedge bulb, you can touch the glass with no harmful consequences.
qwertz9586 is offline
post #4 of 8 (permalink) Old 05-19-2008, 06:28 PM
It could also be a faulty DRL module. It can cause the high beam indicator to not work, or to stay on all the time.
- Barenaked Ladies
Nidan is offline
post #5 of 8 (permalink) Old 05-19-2008, 09:02 PM
They're all just regular bulbs in the cluster (gauge and indicator lights), you can touch the glass. Halogen bulbs are the only bulb you can't touch.
the_intimidator_02 is offline
post #6 of 8 (permalink) Old 05-20-2008, 03:35 AM Thread Starter
no1hedberg's Avatar
Sorry, but what is a DRL module. If it causes it to work intermittently that could definitely be it. I would think a bulb would burn out, and stay out. It seems to have stopped working altogether again. It's never been on while on low beam. Thanks for all your help guys.
1997 Taurus SHO
Got Bull?
post #7 of 8 (permalink) Old 05-20-2008, 02:26 PM
silvapain's Avatar
Daytime Running Lights. Turn off your autolamps, and start the car. Are your headlights on? If so, you have DRL's.
- Daniel
Current:
Past:
1997 V8 SHO Silver Frost -
1997 V8 SHO Ebony Satin -
1997 Vulcan GL -
1990 Vulcan Sable -
silvapain is offline
post #8 of 8 (permalink) Old 05-22-2008, 10:51 AM
Stocker's Avatar
I would think a bulb would burn out, and stay out.[/b]
Not necessarily. Could be loose or have an otherwise bad connection.
Stocker is offline
