How Do You Bypass Park Wire For Cd Player? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 14 (permalink) Old 08-26-2007, 03:06 PM Thread Starter
herter300's Avatar
Send a message via AIM to herter300 Send a message via Yahoo to herter300
i just installed a jensen cd player with a 7" screen and i want to know if there is a way to bypass the park wire so i can have it on when i drive. i've read that you can just ground the wire and it should work but i tried it several times and it just wont work. also my dash had the air bag light and the new one doesnt, is that gonna harm anything. my airbag light gauge is now on. anyway i can fix it without getting a new dash?
Thanks
2005 Taurus SE Vulcan - SOLD
1999 Mustang SVT Cobra
Flowmaster Catback
herter300 is offline
post #2 of 14 (permalink) Old 08-26-2007, 03:07 PM
Don't Be Stupid
Thanks [/b]
With those, there is usually a sequence you have to go through to get it to come on. Do you have your manual?
00tec-satx is offline
post #3 of 14 (permalink) Old 08-26-2007, 03:09 PM Thread Starter
herter300's Avatar
yes i have the manual
Flowmaster Catback
post #4 of 14 (permalink) Old 08-26-2007, 03:15 PM
Don't Be Stupid
Look in there for the certain sequence. Then you will have to install a switch to ground and do the sequence everytime you want it to turn on. It's a little difficult to explain, but if you have problems, let me know.
As for the airbag light, your airbags will not function properly as long as that light is on, to fix it:
Airbag mod (Only for 2004+ models). What you need is a 10k resistor and some t clamps. find the brown/blue wire and the red/yellow wire.
Stip some of the wire covering away and connect the airbag light mod.
post #5 of 14 (permalink) Old 08-26-2007, 03:18 PM Thread Starter
herter300's Avatar
so basically i have to install another switch to ground the wire and then follow the sequence in the manual. got it. Thanks for all the help.
Flowmaster Catback
post #6 of 14 (permalink) Old 08-26-2007, 03:21 PM
tauruskev's Avatar
Aw damn, I just searched for forums for that page. The mods should sticky the How-To for 04-07 Taurus/sable with that Airbag light.
VBulletin Still Sucks.
Fun fact, Toyotas will never die. NEVER DIE.
This fact brought to you by the R.J. Reynolds Tobacco Company
tauruskev is offline
post #7 of 14 (permalink) Old 08-26-2007, 03:25 PM
Don't Be Stupid
so basically i have to install another switch to ground the wire and then follow the sequence in the manual. got it. Thanks for all the help. [/b]
Yeah, the sequence sucks, but you gotta deal with what you have
Here's another article about the airbag light:
Well I did it tonight and I can say this I hate the back of my dash, here is the install procedure i used incase anyone is intrested Warning this was done on a 2005 SE Taurus sedan directions may be diffrent for others. I take no responbility for any damage. Make sure to cover all connections either with the crimp caps or shrink stuff
Parts needed:
10k ohm resistor
Wire taps
The metra dash kit (of course)
Crimp caps
electrical tape
solider
soldering iron
Ford Din keys
Hex screw driver
socket set
torx screw driver
Step one
Remove the factory head unit and the cage that is supporing the back of the headunit
put this to one side for a min
Step 2
Solder on 2 bits of wire to the resistor to create leads for what you are about to do
Step 3
Using taps tap wire 3 Brown/Blue and wire 5 Red/Yellow on the factory radio harness
when looking at the connector with the clasp bit up pin 1 is on the top right side. Using the electrical tape wrap every bit of the resistor and taps so no metal is exposed. (Big warning you dont want this circuit grounding out as it may deploy airbags without warning) put the harness to one side for one min
Step 4 follow the install kits instructions to run the wires from the RCU from the trunk to the dash and wire up your radios harness.
Step 5
plug in the harnesses but leave it danging for a moment and start the car to make sure everything works.
Step 6 Shove everything back in the dash including the aftermaket radio
Step 7 Enjoy!!1[/b]
post #8 of 14 (permalink) Old 08-26-2007, 08:17 PM
Let me know which model you have. There are ways to get around it without a switch.
Just make sure to follow you local laws
unique.kp is offline
post #9 of 14 (permalink) Old 08-27-2007, 05:33 PM Thread Starter
herter300's Avatar
i have a Jensen Phase Linear UV7i
Flowmaster Catback
post #10 of 14 (permalink) Old 08-27-2007, 09:47 PM
1. load dvd
2. wait for dvd to play
3. with the remote push stop twice
4. then push 1,2,6,4
5. then a hidden menu pops up
6. use joystick to scroll down to brake over ride and turn on
7. then click the system setup on the remote twice to save.
Make sure to follow your local laws
