Fuse Location Radio - Taurus Car Club of America : Ford Taurus Forum
Old 09-23-2006, 06:05 AM   #1 (permalink)
Member Number: 3408
Drives: 1997 3.0 OHV
unit731 is on a distinguished road
Yes, I did a search. Yes, it states look at owner's manual. I did. Nowhere do I find the radio listed in the fuse diagram in the owner's manual. I have the owner's manual and it lists a bunch of fuses under dash and in engine compartment. None mention radio. One mentions power antenna. No radio.
2001 Ford Taurus wagon with cd changer in back.
All the heater functions operate correctly. The cigarette lighter works.
The radio does not turn on. The digital clock does now show up. I cannot power up radio.
First I want to check the fuse. Where is it? Does the radio/cd/cassette have it's own fuse?
All else seems to work properly.
unit731 is offline   Reply With Quote
Old 09-23-2006, 06:10 AM   #2 (permalink)
Member Number: 3408
Can I edit a post?
Above should have stated that the clock DOES NOT work. Nothing lights up on the LED panel for radio.
And yes, I pulled the radio/heater module out to check connection. All is connected correctly and tightly. It appears that there is one connection in radio/heater module that goes to radio only.
Old 09-23-2006, 07:52 AM   #3 (permalink)
Member Number: 5295
Well my radio fuse in my '97 is under the dash on the firewall on the driver side. Pull the cover off and you'll see a diagram of the fuse locations.
Old 09-23-2006, 04:29 PM   #4 (permalink)
Member Number: 3408
Originally posted by the_intimidator_02@Sep 23 2006, 07:52 AM
Well my radio fuse in my '97 is under the dash on the firewall on the driver side.* Pull the cover off and you'll see a diagram of the fuse locations.
I know where the fuses are.* Which one is for the radio.
Thanks again.
Thank you. I know where the fuses are. Which one is for radio?
Old 09-23-2006, 10:41 PM   #5 (permalink)
qwertz9586's Avatar
Member Number: 640
Drives: 2003 Ford Taurus SEL
qwertz9586 will become famous soon enough
The one for the radio is tied to the dash/interior lights and key-in-ignition/headlights-on chimer if I remember correctly.
[ 2003 Ford Taurus SEL ] - [ 1995 Mercury Sable GS ]
qwertz9586 is offline   Reply With Quote
Old 09-24-2006, 07:07 AM   #6 (permalink)
Member Number: 3408
Radio fuse.
Everything else operates properly.
Horror of horrors. Could my radio be dead? Is this possible?
Old 09-24-2006, 07:11 AM   #7 (permalink)
Member Number: 5295
Is there no marking on the fuse cover for the radio??? When I had find mine, The fuse cover had a diagram with two fuses for the radio. The fuse for my radio wasn't tie into my park lights. When mine blew at the stereo competion, my park lights were still illuminated.
Old 09-24-2006, 12:03 PM   #8 (permalink)
Stocker's Avatar
Member Number: 9497
Stocker has a little shameless behaviour in the past
I know it was that way with earlier cars, but I haven't had to do a fuse in the '01 yet.
Pull the radio out of the dash and see if the connector came loose. I don't suppose the fuse would be on or around the radio itself, would it?
Stocker is offline   Reply With Quote
Old 09-24-2006, 06:25 PM   #9 (permalink)
Member Number: 5295
Originally posted by StockersAuto+Sep 24 2006, 02:03 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (StockersAuto @ Sep 24 2006, 02:03 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Qwertz9586@Sep 23 2006, 10:41 PM
Pull the radio out of the dash and see if the connector came loose. I don't suppose the fuse would be on or around the radio itself, would it? [/b][/quote]
No, there's no fuses behind the radio itself.
Old 09-24-2006, 11:21 PM   #10 (permalink)
Member Number: 8575
Drives: 2004 SES Duratec
FinnSpeed has a little shameless behaviour in the past
If you did not find it already, there are several fuses affecting radio operation.
In the central junction box (inside, driver's side):
F2.27 10A (hot in start or run)
F2.16 15A (hot all the time)
F2.11 15A (hot in run or ACC)
F2.37 15A (hot in start)
All of the above connect to at least the head unit (control panel).
In the battery junction box (under the hood):
F1.17 20A (hot all the time - power to the RCU & CD changer)
F1.27 5A (power antenna control)
These affect the RCU where the radio and amplifiers are.
-- FinnSpeed --
My car: 2005 Volvo V50 T5 M FWD. Premium Audio, Climate pack, Goodyear Eagle F1 GS-D3 summers, Nokian RSi Winters.
Wife's car: 2004 Taurus SES Duratec. Euro modded exterior lamps, Infinity 6812cf speakers all round, Goodyear Eagle F1 GS-D3 225/45ZR17 94W summers, Nokian RSi winters. SHO Bros km/h gauge faces coming.
FinnSpeed is offline   Reply With Quote
