Factory Amp Bypass? - Taurus Car Club of America : Ford Taurus Forum
Old 07-31-2006, 06:00 PM   #1 (permalink)
Member Number: 9322
beckSHO has a little shameless behaviour in the past
Hello all, I just bought a 97 SHO about a month or two ago. I love the car, it has BALLS! I already put some flomaster 40 series on and it sounds amazing. What doesn't sound amazing, however, is the sound system. It isn't bad for a stock system, but isn't good enough. So, I am going to replace all of the speakers with some quality units. To power them, I will use a 4-channel amp. Now, here comes the kicker... I fried my factory amp! So, I don't get any sound to the speakers, but the radio still tunes in to stations, just no sound. Otherwise, I would have just used a line level convertor to hook up an amp. But now I can't do that. So, here is what I'm wondering, is there a way to completely bypass the factory amp? I mean completely take it out of the mix. I will be running new wire from my new 4-channel amp to the new speakers, so I won't need the factory speaker wiring. Can I toss all of it? If I cut the speaker leads that come out of the bigger black connector from the RCU, where will I get my signal from? I want to use an un-amplified signal. Is there a spot where I can get completely un-amp'd signal for my line level convertor? Pretty much, I want to get rid of the factory amp, and use an aftermarket 4-channel amp to power my aftermarket speakers. So please help me out fellahs (and ladies). Thanks!
<div align="center">1997 Vibrant White SHO: Flowmasters, Un-sax'd, Welded at 113k miles
Head Unit: Pioneer DEH-P6800MP
beckSHO is offline   Reply With Quote
Old 07-31-2006, 06:28 PM   #2 (permalink)
spridget's Avatar
Member Number: 140
spridget has a little shameless behaviour in the past
the factory amp is located in the trunk. You'll need to disconnect the "input plug", use an adpater to use line level inputs to your amp, then run your speaker wires to an adapter and plug that back into the "output plug" from the harness on the factory amp.
http://www.scosche.com/media/pdf/_079_096_harness.pdf
Check Scosche's catalog and contact their tech support to get the correct part number for your setup.
spridget is offline   Reply With Quote
Old 07-31-2006, 06:31 PM   #3 (permalink)
Member Number: 9322
So no matter now I do it, I need to go through the factory amp? I fried mine, so it isn't in working condition. Is it possible to get signal to the speakers without getting a new one?
Old 07-31-2006, 06:44 PM   #4 (permalink)
93 sable's Avatar
Member Number: 1296
93 sable has a little shameless behaviour in the past
Originally posted by beckSHO+Jul 31 2006, 06:31 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (beckSHO @ Jul 31 2006, 06:31 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-spridget@Jul 31 2006, 06:28 PM
So no matter now I do it, I need to go through the factory amp? I fried mine, so it isn't in working condition. Is it possible to get signal to the speakers without getting a new one? [/b][/quote]
If you want to bypass it then you have to install a new radio. The amp is technically called an RCU (Radio Control Unit). The (radio) in the dash is just the controls, the actual tuner and amp are built into one unit in the trunk.
If you have manual climate controls then it's easy to add a new radio. If you have electronic climate controls then you've got to use some creativity.
93 sable is offline   Reply With Quote
Old 07-31-2006, 10:06 PM   #5 (permalink)
Member Number: 9322
Originally posted by 93 Sable+Jul 31 2006, 06:44 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (93 Sable @ Jul 31 2006, 06:44 PM)</td></tr><tr><td id='QUOTE'>
If you have manual climate controls then it's easy to add a new radio. If you have electronic climate controls then you've got to use some creativity. [/b][/quote]
That's weak man, so I need another factory amp (RCU) before I can do anything... That is stupid, Ford did a great job designing this one....
Old 08-01-2006, 12:30 AM   #6 (permalink)
Member Number: 125
The factory amp is pretty good actually. You can put in some better speakers and add a sub woofer. No competition winner but plenty loud and clear.
But then I didn't short the outputs out and burn it up.
Old 08-01-2006, 07:19 AM   #7 (permalink)
Member Number: 9322
Alright, well I guess I'm gonna have to find a new RCU. If you have one sitting around, send me a PM, I'd be interested.
