Converting Manual Seats To Power Seats - Taurus Car Club of America : Ford Taurus Forum
post #1 of 21 (permalink) Old 05-08-2006, 03:07 AM Thread Starter
rogue's Avatar
Is it possible to convert my seats to power seats, usiny my same seats and just switching out the base of it? Would it be complicated for me to do; the most extensive thing I have ever done is changing my spark plugs and wires.
Another question is how much should a power seat cost if I were to buy one from like another member assuming it is possible to just use the base part if the seat.
One last question is how high is the seat when it is at its highest position, measuring from the floor in front of the seat to the top of the seat cushion? I am curious to know how much higher I would sit.
-Jonathan
rogue is offline
post #2 of 21 (permalink) Old 05-08-2006, 10:57 AM
mooby's Avatar
euu you can take any power seat from any car and any year
i just put in some 99 sable seat into my 94 bull and it was just plug and play for the front seat so just get some seat at a scrap yard and you will be fine and get the plug it still the same but some time you need to cut and replace
[img]http://i15.photobucket.com/albums/a358/moobypets/new%20front%20seat/DSCF1270.jpg' alt='' width='1209' height='907' class='attach' />
[img]http://i15.photobucket.com/albums/a358/moobypets/new%20front%20seat/DSCF1269.jpg' alt='' width='1209' height='907' class='attach' />
99 sable eclectric seat in a 94 bull
mooby is offline
post #3 of 21 (permalink) Old 05-08-2006, 03:25 PM Thread Starter
rogue's Avatar
Is it possible to just transfer the bottom part of the seat? I want to keep my seats if I can. How much did you pay for each seat?
Also, I see a plug under the seats with a wire only going to the one under the driver seat. Is that what the power seats plug right in to? Since it is only usually me in the car, I wouldn't bother with the passenger seat, just the drivers seat.
Does the power seat go a lot higher than the manual seat?
-Jonathan
rogue is offline
post #4 of 21 (permalink) Old 05-09-2006, 12:27 AM
mooby's Avatar
it goes a bit higher but it goes lower too and far most in the front and back and they cost me 50 for both with console
and yes you can use onthe the track but ? never done it and not sure if it will fit properly
and for the plug one is the belt and the other is power may need to replace the power witht he one youre getting the seat from
mooby is offline
post #5 of 21 (permalink) Old 05-09-2006, 02:52 AM Thread Starter
rogue's Avatar
From the top of the front of the cushion to the floor with the manual seat height is about 12 inches. How high is the power seat at its highest position?
Is the power plug I could just plug right in to?
[img]http://img89.imageshack.us/img89/5855/driverside0pb.jpg' width='400' height='267.857142857' border='0' alt='Thumbnail - click on the image to get an original view' name='Thumbnail - click on the image to get an original view' class='attach' />
<font size='1'>Thumbnail - click</font>
This is the passenger side plug just sitting there with no power connected to it.
[img]http://img89.imageshack.us/img89/9162/passengerside2qd.jpg' width='400' height='267.857142857' border='0' alt='Thumbnail - click on the image to get an original view' name='Thumbnail - click on the image to get an original view' class='attach' />
-Jonathan
rogue is offline
post #6 of 21 (permalink) Old 05-09-2006, 06:28 AM
Are they wired on the passenger side too?
millermagic is offline
post #7 of 21 (permalink) Old 05-09-2006, 09:11 AM
in the first pic those are the two plugs you need. I guess they didnt use the same wiring harness in that trim model so the passenger side connecter isnt live.
Gaspare is offline
post #8 of 21 (permalink) Old 05-09-2006, 09:44 AM
mooby's Avatar
about 14 inch 15 maybe
mooby is offline
post #9 of 21 (permalink) Old 05-09-2006, 09:50 AM
93 sable's Avatar
Have not touched Taurus seats but I&#39;ve rebuilt a few Volvo seats before. I don&#39;t think you will be able to easily just swap out the manual mechanism for the power mechanism. If you want to keep your seats and go power then your only option will be to remove the foam and seat covers from both seats and transfer yours over to the power ones.
In my opinion the power seats go really high, my seat is as low as it goes, and it&#39;s still to high for me, I feel like I&#39;m riding in a truck. I have to see what I can do about that.
93 sable is offline
post #10 of 21 (permalink) Old 05-09-2006, 07:39 PM
Trader Score: 7 reviews
--Nick
bull geek is offline
