1996 taurus ohv has 215/65/r15 tires and the max psi is 35 what psi would you pump - Taurus Car Club of America : Ford Taurus Forum
post #1 of 24 (permalink) Old 12-09-2012, 07:22 PM Thread Starter
pump the tires too at front and back
The 35 max psi is on the sidewall of the tires
peterf1992 is offline
post #2 of 24 (permalink) Old 12-09-2012, 07:51 PM
I'll Be Watching You!
sousa632's Avatar
Model: Mercury Sable Wagon
I assume the question is what PSI do you run in your tires???
I run 35psi all year round.
John
2001 Sable LS Premium Wagon Duratec, 193K miles and kicking, 2013 Hyundai Sonata GLS
sousa632 is offline
post #3 of 24 (permalink) Old 12-09-2012, 08:27 PM
Radioflyer's Avatar
Send a message via Yahoo to Radioflyer
Yeah I would say 35psi is a good pressure.
Radioflyer is offline
post #4 of 24 (permalink) Old 12-09-2012, 09:12 PM
Peter, are your tires 215s or 205s?
post #5 of 24 (permalink) Old 12-09-2012, 09:45 PM
SloppyJalopey's Avatar
On mine the gas door says 35Psi, I run that in the winter and 40 in the summer because I like the ride a little harder.
2002 Ford Taurus LX - Trans Failure at 350 000 KM
2000 Ford Taurus SEL - DD 260 xxx KM
SloppyJalopey is offline
post #6 of 24 (permalink) Old 12-09-2012, 09:53 PM Thread Starter
what am saying is that on the sidewall on my tires it says 35 PSI MAX so basically what am asking is that since the MAX pressure you can pump them to 35 PSI whats a safe PSI to pump too ok so is it safe to pump to Cold 35 PSI even though the PSI limit is 35 MAX on the tires?
shelia my tires are 215s not the stock 205s
post #7 of 24 (permalink) Old 12-09-2012, 10:13 PM
If the tire sidewall max pressure is 35 psi, then that's the most you can safely run (cold psi of course). Most tires I've seen have max inflation pressures of 40 psi or more, so 35 psi is a pretty low max inflation. What kind of tires are these?
behlinla is offline
post #8 of 24 (permalink) Old 12-09-2012, 10:16 PM Thread Starter
pepp boy tires: cornell 1000
post #9 of 24 (permalink) Old 12-09-2012, 10:21 PM
Peter, you'll be fine with 35 psi cold all the way around.
post #10 of 24 (permalink) Old 12-09-2012, 11:47 PM
My car says to run 31 psi all around, so that's what I do. Careful with running constant pressures higher than what the manufacturer recommends, as could end up with the tire center treads wearing sooner than the sides. For slow leaks, you can usually go quite a bit higher than max pressure to get you home, but wouldn't make a habbit of it.
Borbet225 is offline
