1995 Taurus Door Panel Removal - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 04-14-2010, 07:59 PM Thread Starter
johnsgre's Avatar
Okay, I tried searching the forums and what not to find an answer to this but I couldn't. So I need to replace my mirror on my driver on my 1995 Taurus SE and I think I found all of the screws I need to remove on the door panel but I can't quite figure out how to take it off without potentially breaking it. I can't quite figure out if I need to lift up and pull out or pull out and lift up or something completely different, I've never had a door panel this stubborn before.
Any help would be appreciated because I have to change the mirror either tonight or tomorrow morning so I can take care of my "fix it" ticket that I waited to the last minute to do...
johnsgre is offline
post #2 of 13 (permalink) Old 04-14-2010, 08:22 PM
QUOTE (glowingescape @ Apr 14 2010, 08:59 PM)
Any help would be appreciated because I have to change the mirror either tonight or tomorrow morning so I can take care of my "fix it" ticket that I waited to the last minute to do...[/b]
on my 94 (so prob your 95) there are 6 (im pretty sure) screws holding the door panel on...remove these (and the ones holding the door handle on), then pry around the edges of the panel with a putty knife or similar non lethal object and the panel should pop right off - pull straight out! pulling up, down, sideways, longways, front ways, or any other way will bust those plastic clips...you may end up breaking one of the plastic clips (there are a bunch), but it won't make a huge diff - mine has one, maybe 2 broken (by the prev owner), and it isnt really a big deal...
"Nom-de-plume: when a yard gnome explodes"
coldspit47 is offline
post #3 of 13 (permalink) Old 04-14-2010, 11:46 PM Thread Starter
johnsgre's Avatar
Cool, I have had panels that had to pull different ways, so I was wondering which way to pull with breaking least amount of clips. I will give it a try tomorrow and hopefully it works.
johnsgre is offline
post #4 of 13 (permalink) Old 04-15-2010, 01:38 AM
shady_J's Avatar
Chapter: Northern
Send a message via AIM to shady_J Send a message via Skype™ to shady_J
Here's how it goes:
1. remove upper triangular piece from door (one screw).
2. remove the lowest screw on the pnael. it will be around 2" long and is in the hole just above the map pocket.
3. remove window switch. for complete panel removal, unscrewthe two little screws around a inch long and CAREFULLY lift the switch plastic up and out.
4. remove the screw inside the grab handle on the panel. around 2.5" long.
It's 5 total. as for the bundles of connectors, gently pry on the push clips locking them into each other. a flat screwdriver works well for this. Pry and pull.
Heres a pic i found with all required screws hilighted in red. remove them using a #2 philips screrwdriver, and VERY, VERY gently pry the christmas tree clips until the panel comes off in your hands. once you do it, you'll know how to for other things like speaker upgrade.
[attachment=32837oor_panel.jpg]
Hope this helps.
Shady_J
Shady J
1994 Ford Taurus GL
1997 Mercury Sable GS
2000 Mercury Sable LS
shady_J is offline
post #5 of 13 (permalink) Old 04-16-2010, 03:51 AM
RichmondParkway's Avatar
I've taken my front panels off a number of times for various reasons, and in the process I've destroyed the **** out of those clips.
That's why I bought a box of these off eBay, and it solved my problem of shaky, rattly door panels.
http://cgi.ebay.com/ebaymotors/25-FORD-DOO...=item439e770b5b
Taurus.....NICE!
RichmondParkway is offline
post #6 of 13 (permalink) Old 04-16-2010, 02:19 PM
QUOTE (RichmondParkway @ Apr 16 2010, 04:51 AM)
http://cgi.ebay.com/ebaymotors/25-FORD-DOO...=item439e770b5b[/b]
These look like the clips I need but I really need the grommets they clip into. The ones on one of my doors are missing, or broken so the trim is loose. Any info would be appreciated.
Thanks,
bg505 is offline
post #7 of 13 (permalink) Old 04-18-2010, 02:04 PM
Found my answer on another post. Thanks,
http://www.taurusclub.com/forum/index.php?...m\+grommet
bg505 is offline
post #8 of 13 (permalink) Old 09-09-2010, 08:40 PM
you guys kick ass i locked my keys inside my car and this guy said he could get my car door unlocked with a coathanger for free rather than paying a towing company. ended up screwing my door handle on the inside (i can't open the car door when im inside) so i am gonna take off my car door panel tomorrow and see if i can't fix the problem.
If anyone had a similar problem i'd appreciate any tips. Thanks guys.
Gumby83 is offline
post #9 of 13 (permalink) Old 09-13-2010, 04:05 PM
i did it, most hamfisted as humanly possible but my car is old and has been in alot of cold winters and hot summers so i think i did reasonably well.
For the sake of documentation i decided to show the opposite side of the door panel so you know where everything is that you need. thanks again gents. (fyi this took quiet abit of force for me to remove the panel, the top ones near the lock are a bitch. )
ID:	60287   Click image for larger version
Gumby83 is offline
post #10 of 13 (permalink) Old 03-25-2011, 12:14 PM
Barkentine's Avatar
NAPA has the push-retainer for Gen 1 & 2 door panels in an (8) pack,
P.N. 665-2057 (Balkamp) $5.09.
Or a (25) pack, P.N. 665-2058 (Balkamp) $12.74.
I bought some today and they worked fine.
On both a Gen 1 and Gen 2 I was looking at today, neither required any kind of bushing in the door for the retainer to lock in to. Both just push into a hole in the metal door frame.
Barkentine is offline
