Tire Sizes - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 11-26-2009, 06:49 PM Thread Starter
I have a 2003 Taurus (with aluminum rim) the tire size is 215/60/r16, would it hurt to use 225/60/r16? Thanks
meezee is offline
post #2 of 11 (permalink) Old 11-26-2009, 07:18 PM
No, however your speedometer will be a little inaccurate with the different tire size. This link will tell you the margin of error. FWIW, if you want to go with something other than the stock size, consider some 225/55R16's. The proportions of the tire you asked about above will look sort of tall on your car, but this size has a fat, low-profile look that says "aggressive". IMHO, it fills out the fenders much better than 225/60R16's. Although, your stock size tires will be easier to find a good selection for, since 215/60R16 tires are somewhat more common than the other sizes. Cheaper, too!
Brian_05_SEL is offline
post #3 of 11 (permalink) Old 11-28-2009, 11:15 PM
Year: 1996
Model: Mercury Sable Wagon
QUOTE (Brian_05_SEL @ Nov 26 2009, 08:18 PM)
No, however your speedometer will be a little inaccurate with the different tire size. This link will tell you the margin of error. FWIW, if you want to go with something other than the stock size, consider some 225/55R16's. The proportions of the tire you asked about above will look sort of tall on your car, but this size has a fat, low-profile look that says "aggressive". IMHO, it fills out the fenders much better than 225/60R16's. Although, your stock size tires will be easier to find a good selection for, since 215/60R16 tires are somewhat more common than the other sizes. Cheaper, too![/b]
I was once recommended to try 205-60-16 for several reasons. Stiffer side wall with a 6" wide wheel, better in the snow than the 215. The difference in width is only 10mm(~3/8 inch) and the OD is very close to OEM so the speedo error is small. Not sure if this is sound thinking. But I thought I would throw it out and see if it would provoke any thoughts or comments. If anyone has used this size on their Gen 3 or 4 it would be interesting to hear their experiences.
nbpt100 is offline
post #4 of 11 (permalink) Old 11-28-2009, 11:34 PM
Imaperson's Avatar
Send a message via Yahoo to Imaperson
QUOTE (meezee @ Nov 26 2009, 08:49 PM)
I have a 2003 Taurus (with aluminum rim) the tire size is 215/60/r16, would it hurt to use 225/60/r16? Thanks[/b]
I am running 225/60/16 on my 07 bull, the speedo will read around 1.2mph slow at 60 i believe. No harm done other than filling out the wheel wells just a smidgen better.
Imaperson is offline
post #5 of 11 (permalink) Old 11-29-2009, 01:49 AM
hello, i am running 225-50-16 on my 06 with no problems other then the speedo error about 5mph the improvement in grip is well worth the cost imho
tesmith47 is offline
post #6 of 11 (permalink) Old 11-29-2009, 12:23 PM Thread Starter
Thanks for the replies
I shouldn't have a probably with the different sizes fitting on the stock aluminum rims just as long as I use 16's?
meezee is offline
post #7 of 11 (permalink) Old 11-30-2009, 10:03 AM
animex2's Avatar
Send a message via AIM to animex2
QUOTE (meezee @ Nov 29 2009, 01:23 PM)
I shouldn't have a probably with the different sizes fitting on the stock aluminum rims just as long as I use 16's?[/b]
someone can reply if im wrong, but i think 225 is as wide as i would go with the stock aluminums, and if your sidewall is much bigger then 60 i would start to worry about fender rub.
just raise the taurus a few inches and throw 265/70R16's on it! ahaha (joke)
2003 Green with Metallic Clearcoat 4.7l High Output Jeep Grand Cherokee Overland
1994 White 3.0 MTX SHO
animex2 is offline
post #8 of 11 (permalink) Old 11-30-2009, 11:18 AM
ford_ses's Avatar
225 is the absolute widest you should go on a 6" wide wheel. You'll want something with a stiff sidewall to help with the sidewall flex too, especially if you went to a 60 series.
Even my 225/55s rub the right side inner fender very slightly at right full lock, but it's not a big deal. Whether or not that happens depends on the car...some will do it, some don't - it's very slight. I'd kind of expect 225/60s to touch, and I'm positive they would on my car.
Jim S. - Pittsburgh, PA
Past:
ford_ses is offline
post #9 of 11 (permalink) Old 11-30-2009, 11:23 AM
mwt
mwt's Avatar
http://www.miata.net/garage/tirecalc.html
http://www.tacomaworld.com/forum/tirecalc.php
http://www.tiresizecalculator.info/
http://www.wheelsmaster.com/rt_specs.jsp
http://www.dsm.org/tools/tiresize.htm
Mike
94gl Vulcan totalled 4-01-04
New Paint coming soon
2000 SES Duratec
mwt is offline
post #10 of 11 (permalink) Old 12-01-2009, 10:05 AM Thread Starter
thanks everyone
meezee is offline
