Correct Tire Pressure? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 57 (permalink) Old 02-11-2006, 07:32 PM Thread Starter
A local tire dealer usually inflates my tires to about 40 psi. The placard in my 02 Taurus says the pressure should be 30 psi front and rear. What do you guys use?
hillbilly.wv is offline
post #2 of 57 (permalink) Old 02-11-2006, 07:45 PM
Use what Ford says to use - 30 psi. Your tire dealer is an idiot for overinflating tires that much.
2003 Ford Taurus SES Deluxe
!Duratec Power!
HokieSES is offline
post #3 of 57 (permalink) Old 02-11-2006, 08:03 PM
Interesting... I'm pretty sure my 02 placard says 32 psi... Gonna have to look into that. Anyway werd to Hokie--do what Ford says.
sfontain is offline
post #4 of 57 (permalink) Old 02-11-2006, 08:19 PM
They do that for ride quality. I inflate mine to the max on the sidewall of the tire.
millermagic is offline
post #5 of 57 (permalink) Old 02-11-2006, 09:09 PM
silvapain's Avatar
The higher the pressure, the better the handling and the harsher the ride quality. I personally run 36 psi front and rear. Usually a decent aftermarket tire will allow you to run 40+ psi.
- Daniel
Current:
Past:
1997 V8 SHO Silver Frost -
1997 V8 SHO Ebony Satin -
1997 Vulcan GL -
1990 Vulcan Sable -
silvapain is offline
post #6 of 57 (permalink) Old 02-11-2006, 09:21 PM
KevinMarble's Avatar
I've been a Technician for nearly 16yrs. now... I always set my tires & those of my customers at 35psi. I've found that 35psi. gives the best tire wear, handling, fuel mileage, & ride quality of all. The factory engineers are the idiots!!! They say Explorers/Rangers tires should be set at 25psi front, & 30psi rear. WAY too low for an SUV or pickup of any size... resulting in premature tire failure (the Firestones were fine... underinflation, & poor maintenance was the cause of the blow-outs, & roll overs!!!), poor fuel mileage & "wet noodle" like handling. Therefore I disregard the "specs" & always use 35psi.(except on full size pickups, or larger SUVs) It's worked great for me, try it out & see for yourselves. Most importantly keep up on yearly alignment checks, rotate tires EVERY 6k.mi. , & pay close attn. to balance.
There's alot more to Racing than going in circles!
KevinMarble is offline
post #7 of 57 (permalink) Old 02-11-2006, 09:42 PM
40 is too high as using too much torque on lug nuts.
<table><TD ALIGN=LEFT>
</td><TD TOP ALIGN=LEFT>
98 Taurus SE -Dark Satin Green Metallic Clearcoat = Dark Green
01 Windtstar - Cabernet Red
88 Mustang GT - Oxford White
</td></TABLE>
White gt is offline
post #8 of 57 (permalink) Old 02-11-2006, 10:50 PM
With respect to the tire inflation, by over or under-inflating the tires, you are decreasing the size of the patch of tire that is making contact with the road. Over-inflating causes the center of the tire tread to wear faster. Under-inflating the tires causes the outer edges of the tire tread to wear faster. Properly inflating the tire ensures that the tire makes even contact with the road. This isn't rocket science, just simple physics.
From the Goodyear website:
Frequently Asked Questions | Inflation
How much air should I put in my tires?
Proper inflation is the single most important part of tire care. The inflation pressure on the side of the tire is the MAXIMUM operating pressure. It is not necessarily the right inflation for your vehicle. Always use the inflation recommended by the vehicle manufacturer. You can find it in your owner's manual, posted on the edge of the driver's door, on a door post or on the inside of the glovebox door. Always check inflation when tires are COLD: when the vehicle has been driven less than a mile or one hour or more after driving. Use a good quality tire gauge. Note: It's natural for radial tires to have a slight bulge in the sidewall at their proper inflation pressure. Check or adjust inflation every few weeks, before any long trip or if traveling with a heavy load. And don't forget to check the spare. Your Goodyear retailer can answer any questions you may have about tire inflation.
!Duratec Power!
HokieSES is offline
post #9 of 57 (permalink) Old 02-11-2006, 11:09 PM
@ 33-35lbs. in a bull.
2002 Chrysler 300M Special - 1968 Mustang Fastback - 1994 Subaru Legacy 5-sp.
ex-1995 MTX SHO - ex-1993 Vulcan GL
TrueBlue is offline
post #10 of 57 (permalink) Old 02-11-2006, 11:11 PM
HokieSES is offline
