More responsive gas pedal? - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 13 (permalink) Old 03-28-2014, 08:26 PM
BiGMaC's Avatar
Originally Posted by Brycefking1 View Post
Hey guys, I was just wondering, is there any way to make my gas pedal more responsive? I read on other forums that if you reset the ECU then your car will relearn your driving habits from stock and therefore being aggressive on the pedal making it more responsive. If that's true, how do we reset our ECU? And is there another way?
Just disconnect the battery for 10 minutes.... hook it back up then. Initially the shifts will seem hard... 30-45 min of driving at fast and slow speeds with stop and go wil set the basic patterns. Ford calls it a "drive cycle" If that doesn't work consider looking for a turbo leak in the charge piping or intercooler to throttle-body pipe.
Alternatives that are most common...
1) add downpipes... turbos will spool up about 600-800 rpm quicker (lower than OEM) giving more low end HP and TQ...
2) and of course get a tune... Unleashed Tuning (Torrie McPhail) or Livernois Motor Sports (Dan Millen) would be the top two choices. Personally, I would not use any other tuners currently marketing. Tuning can by modified for the mods you make to the car to maximize responsiveness.
There are also fueling changes... AvGas, racegas, and meth injection
BiGMaC is offline
post #12 of 13 (permalink) Old 03-28-2014, 08:29 PM
The White Falcon's Avatar
Originally Posted by BiGMaC View Post
Just disconnect the battery for 10 minutes.... wook it back up then. Initially the shifts will seem hard... 30-45 min of driving wil set the basic patterns.
1) add downpipes... turbos will spool up about 600-800 rpm quicker giving more low end HP and TQ...
2) and of course get a tune... Unleashed Tuning (Torrie McPhail) or Livernois Motor Sports (Dan Millen) would be the top two choices. Personally, I would not use any other tuners currently marketing. Tuning can by modified for the mods you make to the car.
He has an SE, no turbos.
Bradley.
Holly: 2003 Taurus SES Deluxe, Duratec, spoiler, moonroof, OEM Centennials, JBL Audio system, other enhancements. April '14 COTM winner.
See more details
What's next, 'the eyes that rolled at my massive ego'?
The White Falcon is offline
post #13 of 13 (permalink) Old 03-29-2014, 09:41 AM
Send a message via Yahoo to Daveb673
I've not looked under the hood of a new Taurus. Does it have a plastic intake? If so, a remedy on the Dodge pickups with an electronic throttle is to run a ground wire from the (metal) throttle body to the car chassis. It helped on my wife's 08 Avenger...
A high horsepower Taurus? Have you lost your Vulcan mind?
Daveb673 is offline
03 Taurus SES brake pedal won't engage, no brake ynwia Suspension, Handling and Brakes 6 03-01-2014 08:26 PM
Car makes noise after being turned off, but brake pedal stops it azure Maintenance and Repair 21 01-08-2014 09:55 PM
04 brake pedal questions mike45 Suspension, Handling and Brakes 16 06-11-2013 06:50 AM
Ticking noise when pressing the gas pedal slightly pimpninja Maintenance and Repair 2 05-28-2013 03:26 PM
Brake Pedal Sinks Too Low PLEASE HELP GOING MAD! MrJackhammer Suspension, Handling and Brakes 17 05-16-2013 08:31 PM
