Starting Issues p0627 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #1 of 15 (permalink) Old 05-22-2016, 07:40 AM Thread Starter
Year: 2013
Engine: 3.5L Ti-VCT V6
As of yesterday i noticed the second issue i experience with my car 2013 Taurus with only 59,875 miles. I hit the remote start to cool of my car as it was a lil hot. From a distance i was able to see the taillights on. Once i got close to the car i realized it wasnt on, so i started it and the engine turned walked walked away and tried to put it in drive but it wouldn't budge. I realized it wasnt on. So o started it and the engine sounded like it turned over but it would shut off as soon as it turnes over, giving it gas after starting it did nothing. With no tools or meter to check battery i jumped the car,and is started. Gave it gas and like nothing, but i did notice the check engine light on. So i drove to AutoZone and got error code p0627. Had them check my battery and my battery is working alot better then it should. Decided to drive to a friends house to check my car. engine light still on Upon arrival we ended up talking for a bit when i went to move my car no lighy present. I wonder if my remote start has anything to do with the issues i experienced. Anyone else get this issue.
Chencho is offline
post #2 of 15 (permalink) Old 05-22-2016, 07:50 AM
Gen 5/6 Forum Moderator
Year: 2017
Model: OTHER
Engine: OTHER
According to the Google:
P0627 refers to a problem with the fuel pump, control circuit 'A' open.
The fuel pump is a covered component under your extended powertrain coverage at 5/60,000 miles and this issue may be warrantable. Might be worth a dealer trip, and with very little mileage to spare...
Originally Posted by MY 13 Warranty Guide
(1) Your vehicle’s Powertrain components are covered for five years or
60,000 miles, whichever occurs first. The extended coverage applies to
the Engine: all internal lubricated parts, cylinder block, cylinder heads,
electrical fuel pump, electronic engine control unit, engine mounts,
flywheel, injection pump, manifold (exhaust and intake), manifold bolts,
oil pan, oil pump, seals and gaskets, thermostat, thermostat housing,
timing chain cover, timing chain (gears or belt),
turbocharger/supercharger unit, valve covers, water pump....etc
thefranchise713
Our lives are a series of missions, aided by our gifts and talents, in pursuit of the betterment of our neighborhoods.
thefranchise713 is offline
post #3 of 15 (permalink) Old 05-22-2016, 09:58 AM Thread Starter
Year: 2013
I'f it has anything to do with the fuel pump i wouldn't be able to drive it, and its been working fine, no light on. Runs fine now does it bog down when i floor it.
Chencho is offline
post #4 of 15 (permalink) Old 05-22-2016, 11:20 AM
Year: 2017
Model: OTHER
Engine: OTHER
Reading your post again, you needed to jump the car to get it running? Did the battery ever get tested?
Low voltage does funny things to a car...
thefranchise713
post #5 of 15 (permalink) Old 05-22-2016, 01:00 PM Thread Starter
Year: 2013
Yeah battery did get tested its in extremely good condition
Chencho is offline
post #6 of 15 (permalink) Old 05-22-2016, 08:44 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Was the battery load tested or voltage tested?
jag1959 is offline
post #7 of 15 (permalink) Old 05-22-2016, 09:53 PM
jrdnhsnbrg's Avatar
Year: 2013
Another interesting thing I've learned about my '13 SEL is it starts extremely rough after unhooking the battery. No idea why, but it's only the initial start after reconnecting the battery.
Current: 2013 Ford Taurus SEL
Past:
2001 Lincoln Continental, still running, 190k+
1997 Cadillac Deville, still running, 180k+
jrdnhsnbrg is offline
post #8 of 15 (permalink) Old 05-23-2016, 08:55 AM Thread Starter
Year: 2013
It was tested both ways.
I only jumped it thinking the battery was low.
But since getting it to work on Saturday I haven't had any issues with it lately.
Chencho is offline
post #9 of 15 (permalink) Old 05-28-2016, 10:28 PM Thread Starter
Year: 2013
Starting Issues again 2013 Taurus
So it has begun again. Once again my car has issues starting. The car cranks but it wont turn over. The one think i know for a fact is that i dont hear my fuel pump hum when the ignition is on. I checked the fuses, i replaced two of them the mini fuse and the pink fuse relay, sorry but manual nor is my car close by. I couldn't find the black relay box but did swap it with the one for the fan clutch relay. Still did not start. As started below by Thefranchise13, still have the power train warranty. But i don't want to take it in if it's something else. Just looking as to if any of you have any insight as to where else i can look into to possibly getting my car started. Your help will be appreciated.<br />
<br />
<br />
<br />
Originally Posted by thefranchise713 View Post
According to the Google:<br />
<br />
P0627 refers to a problem with the fuel pump, control circuit 'A' open. <br />
<br />
Chencho is offline
post #10 of 15 (permalink) Old 05-28-2016, 11:11 PM
Year: 2017
Model: OTHER
Engine: OTHER
Threads merged, we can keep it all in this one.
thefranchise713
Idle and Starting Issues Amira16 Engine and Drivetrain 2 11-17-2015 02:54 PM
Replaced Fuel Pump, now having issues starting anwserman Maintenance and Repair 7 07-13-2014 08:16 PM
erratic gauges and starting issues avatar28 Maintenance and Repair 24 01-23-2014 11:03 PM
2003 Taurus starting issues Toawk Maintenance and Repair 1 08-01-2013 09:16 AM
