Member Number: 48769
Drives: 2008 Mercury Sable SE
I just got in from work and decided to check the transmission fluid level. I drove it on the freeway for 25 minutes, parked it on level ground, went one through the gears, then checked the fluid. The fluid level was over hash lines, so I checked it three times and the results were the same. Is the transmission overfilled or should I check when the engine is at a lower temperature?
#2 (permalink) | |
Member Number: 49973
Drives: 1999 Taurus wagon se 24v dohc 169,000 miles
Rep Power: 21 ![]() |
Eng. was idling when checked? How far above the crosshatch area was the level?
![]() Member Number: 49890
Hey! DOHC3.5 mind posting some pics of your car? I need generation 5 tauruses and sables submitted! The entire site would appreciate it on your behalf!!
I apologize for posting nothing to do with your question. Take a picture of the level and attach it here. If it's right at the top you shouldn't have any problems. Please post here: http://www.taurusclub.com/forum/108-...es-header.html
Not familiar with 08 atf dipsticks. How far above the crosshatch is the word "max"?
If it's past MAX, it's really overfilled and you should drain some fluid out to prevent damage.
Does your dipstick look like the one in the illustration?
#8 (permalink) | |
#9 (permalink) | |
Member Number: 46293
Drives: 2001 SEL 24v DOHC 3.0L Duratec
Rep Power: 2 ![]() |
I've seen dollar store turkey basters with well-matched plastic tubing used to suck up a bit of trans fluid. $2 option vs. HF $5-6 option.
Learning whenever I can |
#10 (permalink) |
Member Number: 47124
Drives: 2011 3.5L SEL
I have never checked, but I am sure the transmission would have an overpressure vent on it. In my younger days I had accidentally overfilled a transmission and the excess ended up bleeding out the vent tube with no apparent damage to the trans.
To remove fluid, you could just siphone out with clear tubing (clear so you don't get a mouth full of oil). This works quite well with warm fluid and I've done it many times for a "dump and fil" transmission fluid change on trannies with no drain plug. |
