Member Number: 53193
Drives: 2003
I have a 2003 ford tar that the battery keeps going dead on me. I have had the battery check out and altternator check both are gud. But I can't understand y the battery keep dieing on me. I need help Please
Member Number: 49561
Chapter: Northern
Rep Power: 2 ![]() |
Have you checked to see if there is a light that stays on when the car is shut off? Like cab lights, trunk/cargo area light? How long is it between starts that the battery dies?
![]() 2004 SEL Comfort ~ Shadow Grey Metallic ~ Mach upgrade with Pioneer speakers in the doors and Kenwood speakers in the rear deck ~ tinted windows ~ amber rear turn signal mod |
Drives: 2003
It happen fridayi got a boost off then Saturday I drove it Sunday I didn't drive it and.it Did it this morning
![]() Member Number: 49890
Well how do you know the battery is good? Did they load test it properly or just put this small thing on it and say its good?
I agree. Check for something staying on. If the battery truly is good, then something is draining it or it isn't charging correctly. Sent from AutoGuide.com App
Rep Power: 22 ![]() |
Welcome Andrew!
Graphic Designer
Member Number: 32683
Rep Power: 3 ![]() |
Something could be grounding out. Is there any custom wiring in it anywhere? [New interior/exterior lights, sound systems, etc..]
Member Number: 7489
Other concern is, how long do you run the car after jump-starting it? If it's down to the shopping center and back, you won't charge the battery up enough to do any good. It needs a good, deep overnight charge or a long drive.
"There is no try, or try not. There is only do, or do not." Someday, some hairy big-eared little alien is gonna steal that from me. |
Member Number: 36955
Rep Power: 4 ![]() |
1) Could have corrosion Inside your battery clamps. Brush in side your battery clamps. 2) Your alternator charging wire may be fried out or burnt in the middle of the insulation and not transferring the charge. 3) your ground post could be corroded and compromised. 4)Are your battery clamps on loose? 5) perhaps a parasitic power draw from a bunch of endless sources? You may want to invest in a battery clamp that allows you to twist to disconnect the power until you successfully solve the problem. Google "disconnect type battery clamp". They are about $14. And if you have any accessories disconnect them.
#9 (permalink) |
Member Number: 24956
Drives: 1996 Ford Taurus SHO 3.4L V8
I agree with everyone with the draining idea, maybe you didn't completely shut all your doors (pulled that one before) or maybe you have a loose ground coming off of your battery that isn't giving it a good enough ground charge
#10 (permalink) |
Drives: 2003
Yea I do have a sound system recently put in. Like 3 mnths. Ago
